Power Steering Fluid Type
Old 04-24-2010, 12:40 PM
onelionhunter's Avatar
onelionhunter
onelionhunter is offline
Hi all, I normally hang in the 7.3 SD section, but have a friend with a 1993 f250 with the 351 in it.
My question, is what fluid does the power steering unit take on that truck? I know my SD diesel takes ATF, but have no idea on that one.
Thanks for any help, Tom
Old 04-24-2010, 01:32 PM
subford's Avatar
subford
subford is offline
All Fords take Type "F" ATF.
Old 04-24-2010, 02:05 PM
onelionhunter
Thanks!
Thanks for the info!
Old 04-24-2010, 08:16 PM
jas88's Avatar
jas88
jas88 is offline
You don't even have to use Type F if you don't want to. Any old ATF will do. Type F is getting pretty hard to find these days.
Old 04-24-2010, 08:28 PM
subford's Avatar
subford
subford is offline
The 1995 owners manual still calls for Type "F".
Off the shelf Power Steering Fluid will make a Ford pump make noise.
Old 04-24-2010, 10:14 PM
LCAM-01XA's Avatar
LCAM-01XA
LCAM-01XA is offline
Agreed with Subford, "steering fluid" is bad for the pumps. Dex/Merc-III works decent tho.
Old 03-22-2017, 12:20 PM
fodder2's Avatar
fodder2
fodder2 is offline
I got a chuckle out of this. Owner's manuals don't update themselves?
I've looked up a couple dozen threads on the topic and responses are split pretty much 50/50 between regular ATF and Ford's Type F spec.
Old 03-22-2017, 12:42 PM
Onions.n.Butter's Avatar
Onions.n.Butter
Onions.n.Butter is offline
I always use universal synthetic ATF that covers Mercon V. Synthetic seems to be a bit quieter, although that may just be me convincing myself of that.
Old 03-22-2017, 02:41 PM
fodder2's Avatar
fodder2
fodder2 is offline
I'm always a bit nervous going to synthetic well north of 100k, but at least that probably addresses the 'better viscosity' concerns of using the proper stuff.
Old 03-22-2017, 08:23 PM
BeholdenZippy's Avatar
BeholdenZippy
BeholdenZippy is offline
I have heard of mercon causing more pump noise. I would recommend just sticking with type F. You can find it at any auto parts stores. I even still see it at gas stations.
Old 03-22-2017, 08:31 PM
_Trekker's Avatar
_Trekker
_Trekker is offline
Not true. Mercon V is what is used now. Mercon V can also be used in older trucks.
Old 03-22-2017, 08:32 PM
_Trekker's Avatar
_Trekker
_Trekker is offline
Being a ford tech, I can tell you that Mercon V doesn't make it any louder than type f from my own experience
Old 03-22-2017, 08:34 PM
BeholdenZippy
You would know better than me. Do you know if ford changed the power steering pump design at all after this era of trucks? I noticed that's when they stopped saying to use type F.
Old 03-22-2017, 08:43 PM
_Trekker's Avatar
_Trekker
_Trekker is offline
I don't believe they did, but they don't even use type F in dealerships anymore because everything is replaced by Mercon V or Mercon LV. There isn't much to change on a power steering pump other than pressure or pulley size conidering it is just a simple belt driven pump for hydraulic fluid
EDIT: I would also just like to add that Ford PS pumps are just loud in general.
Old 03-22-2017, 09:17 PM
BeholdenZippy
I was more concerned about the seals. That's why I stuck with type F(don't want synthetic with 23 year old seals). Ford pumps are louder due to the design using spring loaded slippers unlike the Saginaw pumps.
Quick Reply: Power Steering Fluid Type
