1997 Ford f350 7.3 cranks but wont start
I have a 1997 Ford f350 7.3. It has been down for about 2 months. My fiance at the time was driving it and she said that it was running fine then just died. at first I had no idea what the issue was. Then upon further looking i noticed that my chip was only plugged in half way. I believe I have narrowed it down to the injectors not getting fuel. As the fuel bowl continues to fill but the truck will not run. I have tried starting it with starting fluid. And it runs off that. But it will not stay running. Any help is greatly appreciated
The following users liked this post:
- Don't. Real answer, not being a smartass or anything. Wait to start light and check engine light are clues. Tach moving is another clue. Smoke out the exhaust is another. OBDII has codes for bad pcm also.
Get the No Start Flowchart from the FAQ and follow it. It has links to help.
https://www.ford-trucks.com/forums/1...ostic-faq.html
You need an OBDII adapter (SAE j1850 PWM) and pressure gauges for the fuel pressure and HPOP pressure to diagnose this engine without wasting time and money. After much starting fluid you should probably compression check it first. Apologies if it sounds mean, not meant that way.
Is this why you think the PCM might be blown?
Look at the chart and ask more questions. Good luck.
larry51
08-04-2016 07:38 PM
CowboyMoyer66
17
05-13-2016 11:31 PM
