Rear Window Latch Problem
For some reason the plastic latch that is supposed to hold the sliding rear window shut on my 2004 F250 Crew Cab fell off. The latch was intact and I planned to glue it back on as soon as the weather warmed up enough for the glue to work. I planned on using the glue made for mounting inside rear view mirrors to the windshield. No glue works well when applied in really cold temperatures.
Unfortunately while I was waiting for warmer weather, my daughter managed to lose the plastic latch (which I had left in the glove compartment).
Ok, so I need a new plastic latch.
I knew the dealership would want an arm and a leg for this 5 cent piece of plastic but I thought I'd check the price anyway -- but, of course, the Ford answer is "You can't buy just the part you need." Obviously I am not going to buy a whole new rear window assembly just to fix a missing latch.
My temporary answer is to treat it like a sliding door and just put something in the track to keep it from opening; but I'd like to come up with something that is a bit more convenient when I do want the window open.
Any suggestions??
Any suggestions??
Florida Native 72
06-21-2020 03:41 PM
MavJoe
07-19-2008 03:09 PM
