What Oil to Use 88 F250 7.3L
API CD was superseded by API CF-4, CH-4, and CI-4. API CJ-4 can be used where the previous 3 service categories were specified.
If your owner's manual calls for a 30-weight oil (SAE 30, 10W-30), I would stick with it. However, you can also safely use 0W-30 and 5W-30 Heavy Duty Engine Oils as well.
If you have trouble finding 30-weight oils at parts or department stores, you should still be able to pick up a case from a local dealer.
You can still buy API CD and CE rated oils.
The CF-4, CH-4, CI-4 and CJ-4 oils have extra antifoaming agents to deal with the HPOP and HEUI injectors in the more modern diesels.
CD and CE oils foam to much when you have oil pressures as high as Power Strokes run to fire the injectors.
Those addatives will not hurt the IDI engine, but they aren't needed either.
I know a lot of guys that run this oil or that oil.
About one oil change a year, they switch to Rotella.
They all claim the Rotella sure cleans out the engine.
Right now I am running Mobil Delvac 15W-40 in my IDI till I get my oil leak fixed.
Then it will go back to synthetic.
Stroke is about due for a change, and I may try Rotella in it.
IDI is still fine, just used it to tow my sons truck home Thursday night.
Since it is in need of some rust control, now the Stroke gives me transportation while I have it apart this summer.
My lower radiator support is about gone after years of plowing, and I have not found one worth buying.
So now I can cut it up and rebuild it without having to worry about getting it all back together so I can drive on Monday morning.
Front cab mounts are also getting in bad shape, so I think I will pull the cab to fix them.
That was out of the question when I only had two days to take it apart, fix them and get it back together.
So it is not going anywhere, and will finally get some much needed TLC for the body.
It's still going to be my serious work truck for the heavy towing and hauling.
As for the Stroke, still slow as a snail, but I did buy a 3" downpipe and 4" exhaust that should help it a little.
Trying to figure out how to do something about the air intake system, it leaves a lot to be desired.
1025, 73, 88f250idi, diesel, e350, ford, idi, international, kind, oil, powerstroke, put, recommendations, sterling, weight
