1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Firestone ride-rite airbag install 08 F250
Old 08-01-2010, 04:24 PM
vairman's Avatar
vairman
vairman is offline
Finished up last night
I finished the install yesterday. I basically did the same install as SENIX but connected direct to the battery with a 30 amp fuse and connected to a switch and then to the compressor.
Old 08-01-2010, 07:07 PM
Kajtek1's Avatar
Kajtek1
Kajtek1 is offline
I don't have the manual, but my compressor works on 10 amp supply.
Still think hooking up via ignition relay would be wise idea. If you forget to turn it off and you have air leak -that will drain the battery if the compressor will not burn before. Those compressors are design for like 20% duty.
Old 10-25-2010, 11:52 PM
RedNNBlue's Avatar
RedNNBlue
RedNNBlue is offline
Spinella, I see that you mounted your compressor behind the seat. How's that working for you?
I just got a Viair 350C compressor and 5 gal tank to install for the new bags and horn.
I have an '02 F-250 Ext-Cab, and am thinking that I want the compressor behind the back seat also. I'm a little concerned about the heat from the compressor though. Is it going to get hot enough to worry about? I think the top of the compressor will touch some of the fabric on the back of the seat panel.
Any help or advice anyone has will be appreciated.
Old 10-26-2010, 07:21 PM
spinella's Avatar
spinella
spinella is offline
i'm having no problems with it mounted back there. (second truck i did this on) my truck is a crew cab so i'm not sure how much room you have. here in n.y. we have road salt and i dont think that little commpressor would last very long if i mounted outside the cab. i dont think you would have any trouble. i'll take a picture when i get a minute and i'll post it.
Old 10-27-2010, 12:46 AM
RedNNBlue's Avatar
RedNNBlue
Thanks for the help!
I'm not sure about the difference in the back seats either. I kinda thought they'd be the same back piece, but could be wrong. Mine has 2 or 3 clips on the top that slid into slots just under the rear window and 2 brackets on the rear wall that some rectangular pieces of the seat back frame latch into. There's only a few inches of room back there. I did speak with someone from TrainHornsofTexas.com that sold me the compressor and tank. They said the pump could probably be okay underneath and better with the filter inside, but recommend the entire pump be installed inside if possible. They also said that the compressor shouldn't get hot enough to cause any concern.
Old 01-15-2012, 03:36 PM
Wildcat Fan's Avatar
Wildcat Fan
Wildcat Fan is offline
senix - Any details you can share regarding what you did with the fuel lines on the driver's side? I'm in the middle of installing mine and am working on the driver's side. Just not sure how much play there really is with the fuel lines. The install kit came with a bracket, but it's not clear where I would even use it. Did you just push the lines out of the way? In order to do anything, it looks like I need to remove the clip holding them in place (not sure of this plastic clip is reusable - appears to be a press fit into the frame. Can I just pull it out of the frame hole?). I appreciate any insight.
Old 01-15-2012, 04:57 PM
senix's Avatar
senix
senix is offline
Received 1,418 Likes on 1,013 Posts
You can just pull it out of the hole and then push it back in. Other than that nothing else had to be moved that I recall.
Old 09-08-2013, 06:01 AM
Dascro58's Avatar
Dascro58
Dascro58 is offline
Scott,
Sorry for resurrecting an old thread. I'm in the process of installing these airbags on my 2010 F-250. Do you recall if you used the fuel line relocation bracket included in the kit or did you just remove the fuel line retaining clip to allow enough room to install the upper air bag bracket and then put the fuel line clip back in the original location/hole in the frame?
Thanks,
Dave
Old 09-08-2013, 06:10 AM
senix's Avatar
senix
senix is offline
Originally Posted by Dascro58
Scott,
Thanks,
Dave
Used the original fuel line clips. I just removed it to allow access then put it back.
I ran my airlines along in inside frame rail all the way to the skinny pedal with the fuel lines as well.
Old 09-08-2013, 06:27 AM
Dascro58's Avatar
Dascro58
Dascro58 is offline
Thank you for the quick, helpful response Scott. Especially to an old thread and for recalling something you did three years ago. Impressive!
Dave
Old 09-08-2013, 06:30 AM
senix's Avatar
senix
senix is offline
Dave
You're lucky as I just sold the truck last week for a 2013 dually.
But I was under it removing my CCV mod.
Old 09-08-2013, 06:46 AM
Dascro58's Avatar
Dascro58
Dascro58 is offline
They say timing is everything. . It worked for me this time.
Your new truck is very nice! Do you think you'll put airbags on the dually?
  #28
Old 09-08-2013, 07:00 AM
senix's Avatar
senix
senix is offline
Not at this time.
With the camper package and the duals plus over loads I only lost two inches when hooked up.
But then again I did not have a full load in the 5er yet.
Maybe only 20 gal of water...but I hold 100.
  #29
Old 09-08-2013, 04:29 PM
Dascro58's Avatar
Dascro58
Dascro58 is offline
That is a very nice looking set-up you have there. Very nice!
I installed the airbags on my truck today. The install wasn't too bad at all. Your experience and input on simply putting the fuel lines back in their original position made the install much more straight forward, IMO.
Enjoy that new truck and camper!
Dave
  #30
Old 09-08-2013, 04:52 PM
senix's Avatar
senix
senix is offline
Congrats on the install. You will find them quite useful.
JRC99408
51
03-15-2021 08:25 PM
bad_habit_F350
16
06-02-2020 10:54 PM
BLADE35
01-08-2015 04:50 PM
ruschejj
6.7L Power Stroke Diesel
28
02-26-2012 03:44 PM
charbaugh
13
02-20-2012 02:11 PM
Quick Reply: Firestone ride-rite airbag install 08 F250
