help with carb and intake
i have a 1965 f100 shortbed it now has a 289 motor , i was told that it had a 750 carb. on it(i don't think so)..........need to know what i got....the number that is on the left bottom of the carb. is 1405 0928, also the motor has a aluminum intake that has a ford emblem embossed in the middle of it the number on it is in the back left corner and it is rf-e4ze-9425-ga any info will be greatly apprieciated
Thanks for the info COMPMAN25!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
it is a edelbrock carb..........so that means it is a 600 not a 750 correct???
it also makes a popping noise in the carb when you get on the trottle........what is wrong?????
it has a brand new mallory duel point distributor in it , is it possible that the points are not set right and do you set them ???????????????
asmith6
24
08-21-2016 04:27 AM
rebocardo
26
01-05-2016 09:25 AM
flipboard7431
04-22-2015 08:16 AM
J Hodges
03-21-2008 07:53 PM
38, 9425, 9425ga, carb, e4ze, e4ze9425ga, ford, ga, good, intake, performance, rf, rfe4ze, rfe4ze9425ga
