6V Temp Sensor for 302 intake?
Old 04-06-2010, 11:44 PM
polarspeed's Avatar
polarspeed
polarspeed is offline
Hello, I am trying to convert my stock gauges for my 51 F1 to the 302 SBF intake manifold. The temp sending unit is huge. Has anyone gotten this to work for either the stock 2V intake manifold or the Edelbrock Performer Intake manifold (#2121)? I have the speedo issue solved so that it can be used with my 5 speed manual transmission, but waiting on the oil pressure sending unit. Is there a 6V sending unit for oil pressure? I can't find one.
Thanks, Steve
Old 04-07-2010, 12:01 AM
Julies Cool F1's Avatar
Julies Cool F1
Julies Cool F1 is offline
Why don't you convert to modern mechanical gauges that will fit your engine, that you don't have to voltage reduce and you don't have to adapt 6 volt electrical sending units that are expensive to buy - if you can find them.
Adapting 3 1/2 inch Supro mechanical gauges into your existing gauge cases and using the stock faces is a relatively simple process that only requires some minor cutting of the stock gauge case.
Look in my Galleries. There is a gallery that tells you the step by step and has a picture of each step.
I have done this with my oil and temp. Ammeter does not need to be modified, and gas gauge can be voltage reduced.
Here is a picture of my gauge package after the conversion:
Name:  N. New gauge assembled.JPG
Name:  9. Guage Package Restoration.JPG
Old 04-07-2010, 01:19 AM
HD74's Avatar
HD74
HD74 is offline
I'm using the old oil pressure sending unit with my 12v system. I just added a voltage drop to the gauges. As noted in the picture and it works fine. On the amp meter make sure you run the wire thru backwards or it will show that your discharging instead of charging.
As your looking at the back of the gauges, normal 6v pos. grd. would run thru the hoops bottom to top. 12v neg. grd. start at the top loop than down and around to the breaker bar.
Old 04-07-2010, 08:00 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Doug51F1 has installed the stock flathead type sender in his 302.
Rusty_S
29
04-10-2018 04:25 PM
76F100guy
05-26-2015 08:40 PM
Gigemags05
1947 and Older Ford Trucks
11-14-2014 09:55 AM
benbuilder
06-23-2014 06:58 AM
barthel
Modular V10 (6.8l)
08-11-2013 10:45 PM
Quick Reply: 6V Temp Sensor for 302 intake?
