Has anyone done this? What size tubing will i need? 3/8"? If you have done this mod, how long does it last? Does the tubing get smashed enuf over time that it stops benefiting ? FOr an extend cab truck, how much will i need?
For a crew cab, 60' should be plenty and u will have some left over. I think i will still buy 60' just in case for my Ext Cab. Im stopping by Lowes tonight i think while i am out and about.
Thanks crum. good info there. Im going to try and get some from Lowes since i want to do this this weekend, im tired of road noise coming through the doors
You pull it through the inside of the factory door seal. The factory seals are basically a piece of tubing thats shaped to seal the door. You're pulling a smaller tube through the larger factory one. Make sense?
I'm another one sick of the road noise, I never thought these door sealers would go bad so darn quick, man, I even applied door sealing treatments overs the years vigoriously. Subscibing again but not for the 200.00 stuff Layson mentioned lol, wow.
