Doing the door seal mod on the EX!!!
Originally Posted by ExcursionUSA
CptSD:
Hey, thanks for the detailed post and instructions. I'll try it this weekend... just one question:
Is the vinyl tubing available at improvment stores such as Home-Depot or Lowes?
Which department would I look in? Or where did you get yours?
Thanks for the help
Andy
Thanks for the help
Andy
Good luck with this mod I know you will be happy with the results.
Get in touch if you have anymore ??
JB
CptSD:
Thanks for the help
Andy
Thanks for the help
Andy
I did all four doors, it was piece of cake to do
Thanks CaptSD for the tip about marking end joining point
Originally Posted by ferraridriver
Did mine today, got the tubing at Home Depot, lawn sprinkler/copper tubing section. Comes in 10 or 20 ft rolls, you will need the 20 ft roll. About $3.50/roll Thanks CaptSD for the tip about marking end joining point
Do you have any pics? I am still trying to visualize this. Thank you.
No Pics, sorry
The only hard part is feeding the seal down through the interior molding on the driver’s door, (The one that is held on by the hood release handle). Just lube it up and work the seal down from the top
All four doors took about a half hour and $16.00 worth of tubing. (4 20ft rolls)
I think the doors are a bit too hard to close with the vinyl tubing so I just bought some latex tubing on eBay. When it gets here I’ll change it out.
Should be easy ‘cause I can use the vinyl tube to pull the latex through.
<O
I’m going to use baby powder to lube it instead of soapy water.
<O
http://cgi.ebay.com/LATEX-RUBBER-TUBING-1-4-in-ID-X1-16-in-WALL-X-50-NEW_W0QQitemZ270156248339QQihZ017QQcategoryZ26261Q QssPageNameZWDVWQQrdZ1QQcmdZViewItem<O></O>
<O
<O
<O
<O
<O
<O
on
I just came back empty-handed from Home Depot. I went to get the 3/8th inch OD vynil tubing, which they had plenty of, but left it on the shelf. It seemed a little small to me. Is this for real? The smallish tubing seemed a little like putting a pencil in a garden hose. Is it enough to really make a difference? Really?
works well. very stiff im in texas so im not worried about cold cold
#28
Will this work on power vent window????
Would anyone know if this is a fix for a leaking rear vent window (the power vent)? Mine leaks occasionally and is more annoying than anything else. I would also like to know what is better for cold climates. I'll look at the surplus stores for silocone or something similar and let you know what works. If no replies.
It won't be too soon. I wish it would just stop raining. 6" last 2 days , about 3/4" tonight/now , on top of saturated soil. (Hurry up Noah the waters are getting deeper) I'm ok the EX pulls through high & dry.
All the doomsdayers are having the time of their life. I can't wait for the mother ship to pick them up so I won't have to listen to their line of **** any more.
I would like that leak fixed though. It leaves streaks on 2'nd row rear armrest and the side panel. Thanks. Rich.
#30
I'm in Buffalo, NY and I had to switch to the latex part way through the first winter after I added the tubing. The vinyl became hard as a rock and the door became hard to close. The original foam rubber was getting crushed. When I pulled the vinyl out, it had taken a permanent oval shaped set. I have found the latex to be just as soft at 0 Deg F as it is in the summer.
Latex is the way to go for those of us in the North. It was a few years ago, so I'd have to measure mine again to remember what sizes I used.
