HFCM bolt stripping cant get it out help please
Okay so I finally locate fuel filter package and bought my new filter caps to throw the aftermarket ***** out engine compartment goes wonerfully I got the broken cap off with a stanley chisel and hammer now I'm doing the big filter and cant get the water drain plug out I would also like to replace with the new updated one for about $20 can someone help me its stripped decently already and it is snug as a bug I can assure you ideas please! thank you!
Sometimes if you strip it out you can go with a metric allen or even next larger american size which might be just big enough to allow you to tap it in wedging it enough to break the old bolt loose.Other than that might try drilling it out but be careful to drill the center. if successful clean very good don't want shavings in system. Good Luck
ok update before the last post I made the bolt has been sitting in wd40 for about half hour just went out and put all my strength into getting the stupid thing loose and it wont budge it did not strip too bad when I was out there but the bolt is pretty rusty I was about to snap the allen key and end up ripping the fuel assembly out that sucker is in there so good tight! I need to get this thing out! while I have my day off lol!
It's a 6mm hex (.236) so if you strip it out you might try a 1/4 inch allen wrench.
Okay I'm getting extremely frustrated now I have been farting around with this stupid bolt for the last few hours trying to get it out to no avail I've soaked it in wd40 3 times and have been tugging on it to no mans end there has to be a way to get this stupid thing out can someone please help me the bolt isnt completely stripped (yet) but it is just so extremely snug the previous owner mustve thought hes hercules some one help!
wd40 wont help. the threads are past the o ring. Dont take this the wrong way but are you sure you are turning it the right way? is truck 2wd or 4wd? I know the dive shaft is in the way on 4wd. if yo can get the allen in and seated good and tight give it a sudden impact instead of a steady pull. That might breag it loose. Good luck
yes turning the right way unless righty tighty left loosey does not apply for this water drain bolt yes the truck is 4wd bolt is already stripped 6mm wont sit snug now tried to get 7mm in but to big and cannot hammer it in because the driveshaft am I going to have to drop the driveshaft to get this stupid thing out?
