How much power steering fluid?
I inadvertently drained my power steering fluid while installing my red head gearbox. Oh well. What I'm not sure of is how much fluid it takes to refill the system. I have a quart on hand but wanted to know if I needed to run to the store to get more, and if so, how much.
Thanks,
Ted
Thanks,
Ted
I don't have a capacity listed in my Owner's Manual - I believe it was just over a 1 quart when I did mine and I let it drain for quite awhile. I even used low pressure air on the line to get as much out as I could. After you add fluid - make sure you do full turns lock to lock to bleed any air out of the system.
Same thing on the gassers - it's transmission fluid. I'm just in the habit of referring to it in general terms as power steering fluid.
