How much power steering fluid?
Old 03-29-2010, 06:53 AM
Ted Bell's Avatar
Ted Bell
Ted Bell is offline
I inadvertently drained my power steering fluid while installing my red head gearbox. Oh well. What I'm not sure of is how much fluid it takes to refill the system. I have a quart on hand but wanted to know if I needed to run to the store to get more, and if so, how much.
Thanks,
Ted
Old 03-29-2010, 07:21 AM
tdappleman's Avatar
tdappleman
tdappleman is offline
I don't have a capacity listed in my Owner's Manual - I believe it was just over a 1 quart when I did mine and I let it drain for quite awhile. I even used low pressure air on the line to get as much out as I could. After you add fluid - make sure you do full turns lock to lock to bleed any air out of the system.
Old 03-29-2010, 10:50 AM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
I'm not sure how it is on gas trucks, but on my Diesel X not one drop off Power Steering Fluid is supposed to go in there. You're supposed to use Mercon V or better...I used Mobil 1 Synthetic to when I flushed mine out last year.
Old 03-29-2010, 10:57 AM
Ted Bell's Avatar
Ted Bell
Ted Bell is offline
Same thing on the gassers - it's transmission fluid. I'm just in the habit of referring to it in general terms as power steering fluid.
Old 03-29-2010, 12:49 PM
tdappleman's Avatar
tdappleman
Agreed - I used Amsoil Synthetic Universal Transmission fluid in mine. Had a slight whine prior to the flush which is what prompted me to do it - not even a hint at the noise now.
Amelio
6.7L Power Stroke Diesel
22
02-08-2020 06:09 PM
Ted928
2004 - 2008 F150
10-29-2016 09:47 AM
Toakley123
16
10-15-2016 06:53 AM
Deuce40s
1999 to 2016 Super Duty
10-02-2016 08:04 PM
Ted928
2004 - 2008 F150
09-20-2016 06:00 PM
Quick Reply: How much power steering fluid?
