95 F150 5.0 Exhaust Flow??
Old 03-21-2010, 01:39 PM
FlyCool5.0's Avatar
FlyCool5.0
FlyCool5.0 is offline
Question 95 F150 5.0 Exhaust Flow??
Hey Guys,
I have a magnaflow replacement downpipe+cat. Now I hear the sound of the exhaust flowing down the pipe. Its a very annoying sound. Was the reason I never heard the sound with the stock downpipe becasue the two pipes met in a resignator? The magnaflow just meets the two pipes by welding them together. Was the purpose of the factory resignotor to dampen the sounds of the exhaust collecting as the two pipes from each side of the engine meet?
Thanks
Jeremy
Old 03-22-2010, 04:07 PM
dkf's Avatar
dkf
dkf is offline
Have a pic of the magnaflow setup you got? Any exhaust leaks?
Old 03-26-2010, 12:57 PM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
There is no resonator on the stock setup. The original setup had two converters, and the headpipes did join together into the front converter. Magnaflow eliminates one of the original converters because a three way converter can replace the function of the OE converters. However a smaller three way cat does not replace the sound absorbing qualities of the OE setup. So I can see how you can get strange sounds.
Here is a picture of the Magnaflow setup
Here is a picture of the proper setup
I know which one I would get. Don't know what you paid for the Magnaflow, but they have tendency of giving you less than what you deserve because they are a big brand name and Mario Andretti doesn't come cheap.
Old 03-26-2010, 11:20 PM
FlyCool5.0's Avatar
FlyCool5.0
Thank You! I Had Been Trying To Find The OEM Setup For A Long Time. Now We Will See How Many Arms & Legs I Will Have To Give To Get It. That Is The Exact Magnaflow setup I Have (Which Was Horrid To Get To Fit!).
chesster51
13
01-05-2015 05:59 PM
Revs F150
03-20-2012 09:17 PM
svt2205
5.0L Coyote
12-31-2011 06:06 PM
mattsf250
10-04-2009 05:59 PM
Tungsten
09-18-2008 02:10 PM
Quick Reply: 95 F150 5.0 Exhaust Flow??
