Testing the Ignition Control Module?
Old 03-18-2010, 10:23 PM
padlikehel's Avatar
padlikehel
padlikehel is offline
Trailering
Is there a way to test the ignition control module for EEC-IV with common tools, i.e. multimeter, test light?
Old 03-18-2010, 10:40 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
Nope. None that I know of.
Old 03-18-2010, 11:38 PM
babarche's Avatar
babarche
babarche is offline
This may help:
SBFTech.com TFI Module/Hall Sensor Testing Procedure
Some good stuff here (Ranger based but applicable since it is a similar system):
The Intermittent No-Spark Ranger
Ford Ranger/Bronco II TFI Ignition Diagnostics
Most parts stores can plug a suspect ignition module into a special tester if that is an option for you.
Old 03-19-2010, 07:57 AM
rla2005's Avatar
rla2005
Originally Posted by babarche
This may help:
Great info! Thanks for the links.
brokeasajoke
08-24-2016 03:20 PM
TGH
1978 - 1996 Big Bronco
07-27-2016 11:43 PM
Motorhead-42
80
07-27-2016 02:30 PM
imyogybear
1966 - 1977 Early Broncos
11-12-2015 05:07 AM
Gruntface
04-07-2012 12:03 PM
Quick Reply: Testing the Ignition Control Module?
