F250 clutch/transmission
I have a 2000 F250 with a 5.4 and a 5 spd. I think the clutch hydraulics are bad because while holding the pedal all the way to the floor the truck shudders and tries to move, and is difficult to downshift while moving. The shifting difficulty goes away when the engine is shut off. But it also has a tapping noise while driving around 2000 rpm. The tapping goes away with the clutch depressed. Would that be associated with the clutch problem or does this mean the transmission is also going bad? I think the clutch constantly trying to engage may have worn on the transmission, but i hope that is not the case
you can start by checking the master and seeing if you are low on fluid. Then I would be getting up under there and checking your linkage.
I almost sounds to me like a linkage problem where you think your depressing it and it really is not giving it enough to release the clutch so you can shift.
yeah that is not normal. So same effect as I was saying, when you are depressing the clutch is not going far enough to disengage the clutch and the trans to allow for shifting.
Tightening that up may be the one and only cause or there may need to be some adjustments down below required, but that is a good place to start.
