Clunk during upshift after Pinion Seal replacement ...
So I replaced my leaky pinion seal .. it was slinging oil all over so it was time. I went ahead and ordered a new flange along with the seal, pinion nut, & drive shaft flange bolts as I had high suspicions why it was leaking. Upon disassembly, I found my suspicions to be correct .. the original pinion flange was grooved. No leaks now!
Anyway, the job went resonably smooth ... I measured preload before and after and generally felt things were good when I buttoned it back up. I detect no side-to-side or up-and-down movement at the pinion flange and had a slight drag w/ about a 12 in lb preload.
Test driving afterwards, I hear no sounds during acceleration, coast, or deceleration. I can stomp the pedel at a coast and hear nothing, and I can let off the pedel during a hard acceleration and hear nothing. The housing is not unresonably warm after a good drive.
But, what I am hearing now is a "clunk" when the auto trans upshifts from 2nd to 3rd during a mild stop light acceleration. I'm 95% sure this was not there before the job. The first thing that came to mind was a backlash probelm .. but what could I have done to change the backlash? Anybody have any ideas as to a cause?
I'll eyeball 'um again just to be safe ...
No this is the 10.25/10.5 axle, it has a crush sleeve so he did it correctly by measuring pre-load. The dana 80 has a specific tq spec (470#)
