adjustment sleeve
well i put a 92 ram 2500 solid axle under my 91 f350 and hooked the dodge tie rods up the threads at the tie rod from the pitman arm and the main tie rod are to far abort when adjusted to the steering wheel like maybe 1" of thread holding on each tie rod when i get the threds sucked up it turns either 1 turn right and 2 turns left of viseversa
So, you are trying to connect the drag link (from the pitman arm to the tie rod)?
Are you trying to use all of the Dodge steering linkage?
What adjustment sleeves are you trying to use to make the connection? On the tie rod itself?
Is there any adjustment on the drag link or is it solid?
Jason
Jason
There are a couple of ways I can think of to solve your problem.
1. DOM tubing and spherical rod ends with a true crossover steering setup.
Kinda spendy and can be a PITA on a daily driven ride.
2. Do some research at the parts store (or online) to find an adjustable draglink that will work with the Dodge tie rod.
I'm assuming that this truck was originally a 2wd. I'm wondering if you could use a complete steering linkage from a 86-97 F350 4wd. What is the center to center length of the Dodge tie rod?
Jason
Jason
well i got the adjustment sleeve built an on tonight. i basically cut it in half and welded it inside a piece of schedual 80 steel pipe and it worked out great. this is just a temporary till summer till i can get my drop pitman arm on and do the entire crossover steering system out of chromoly DOM tubing
61 uni
11-03-2012 01:04 PM
