Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: 4WD Guides
- How to Replace Transfer Case
Step by step instructions for do-it-yourself repairs
4406-21 Transfer Case, Replace or Rebuild
My transfer case has been making some grinding noise while driving down the road. The grinding noise starts around 40 mph and the noise level increases as speed increases. I've heard it for a while, but haven't been able to pin point the noise to one area or part.
I finally locked down the transfer case as the problem this weekend. While driving down the freeway, I had this odd inclination to grab the transfer case shift lever and pull it to the left slightly. As soon as I moved the shift lever to the left, the noise decreased substantially. It did not diminish completely, but almost.
Once I got home I put the transfer case into Neutral and then put the transmission into overdrive to simulate driving down the highway. I got under the truck and pin pointed the noise to the transfer case. I believe the noise is traveling through the shift lever into the cab.
I've spoken with a Jeep guy at work, and he explained that it might be the chain in my transfer case slapping on the case. Does this sound right? It makes since to me. The noise does not occur while the vehicle is in 4x4.
What should I do now?
Should I have the transfer case rebuilt? (It has 170,000 miles on it)
Will I be able to muscle it down and back up into place?
I read in another thread that the transfer case needs to be aligned. Is this true?
A re-manufactured transmission is out of the question. I've got one quote for $1200 and I don't have the funds to buy a re-manufactured transfer case.
I spoke with a local driveline shop and they said it would cost $175 to drop the transfer case, $175 to open the case, and then around $200-$300 in bearings, chains, and seals.
Or should I replace it with a transfer case from a junkyard?I've found a transfer case from a local junkyard with 78,000 miles for $250. I think I'm leaning towards this route, since my transfer case has so many miles on it, unless you convince me otherwise
How hard is it to remove and replace the transfer case?I've called 2 local driveline shops, and they want $175 to remove the transfer case and replace, if I decide to go that route. I'm used to doing all the wrenching on my truck, but I just moved to Vegas and don't have the garage space and tools like I used to have. I have a coworker that is willing to let me work in his driveway and he will help me, but I'm not so sure I can complete this in a day, unless you tell me otherwise.
How much does the transfer case weight?Will I be able to muscle it down and back up into place?
if you really push it, it can be done in a day, but you willl get frustrated at that pace... two days minumum and you should be golden. 250 is a steal, if it is in good shape with no play. it can be mussled in and out, but it is a VERY good idea to have a good floor jack under it. it is amazing the difference it makes. no alignment required. there is a pin that makes sure it is square with the world and then just torque down the bolts and loc tight them. you do need to jack up the front, unload the torsion bars, and remove the torsion bar cross member, BFH and hit towards the back of the truck.
oh and as far as i know all the cases are the same except some have floor shifters and some shift electronically.
that is a very good point. to me it was worth it to save around 500 bucks and buy used.not to mention what i saved by doing it myself. i have almost 7000 miles on my 'new' case and it is perfect so i got lucky. i would be very surprised if they (the shop) could actually get this done in three hours. that is really cooking. now if i had a fancy lift and had done several before i probably could have done the whole project in one day. even without those advantages i probably could have... but i wast worn out, and not really in any hurry. personnally i would do it myself if i were you and just take a weekend and a buddy and do it. but i like to know how my truck is put together and what makes it tick. plus it should be cheaper to buy your friend a case of beer than pay a shopbut thats just me. good luck with whatever you decide.
He could save some money by taking it out, take it to them to rebuild and then put it back in himself too.
Check to see if your local yard offers a warranty with the used case. For the cost and time savings, I'd go with used if it's got a good warranty. Alldata shows 4 hours to remove and replace the case. And as far as which is better, if you only use yours a few times a year, the best case is the factory case. What you've got is good, but there are better ones out there; however, the time, money, and trouble to upgrade would moot the whole point. My truck has the BW 4406 and I've beaten the snot out of it and it has served me well. It has 250k miles on it with no troubles.
All of this feedback is great.
I agree completely, I enjoy working on my truck and seeing the innards (that's a technical term). It took me 4 days, but I installed the lift kit by myself on my truck. It makes fixing the next problem easier because I can already visualize the components and how they work together. However, that was much easier when I was back at home with access to tools and extra vehicles. I just moved to Vegas a month ago and I'm living with a coworker. So I only have the tools in my tool box and having my truck out of commition for a few days while a shop fixes it is a major inconvenience.
I believe that I'm going to buy a used transfer case for $250 with 75,000 miles and pay the shop $175 to pull the old and place the new. I understand the concern that "you don't know what you get" when buying used. It's a gamble I think I have to take. I'll say a prayer over the transfer case before putting it in.
