anyone have a wiring diagram for an old dominion auto signal switch?the kind that gear-clamps to the column? mine is a 7 wire and i cant find a diagram!
It`s a universal after market add on signal switch for vehicles without factory signals.
I`d try Acklands, a semi truck dealership or any after accessories market dealer that sells the Dominion Auto accessories, see if they can come up with anything.
i might have a diagram from my turn signal switch give me a few mins and i ll see if i can dig it up, its a stock factory switch but its been rewired for my custom harness.
no the flasher is separate, its like 6 contacts inside and when the switch is in the left position it connects 2 contacts to make the circuit, when in the right position it contacts 2 other contacts and when its in the neutral position the current bypasses the switch altogether as far as i know
