Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1973 - 1979 F-100 & Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
  #1 (permalink)
Old 03-07-2010, 06:32 PM
MonsterTruck\m/ MonsterTruck\m/ is offline
Garage is empty, add now
MonsterTruck\m/ is starting off with a positive reputation.
spray in bed liner for cab interior?
Hey I just put in new floor pans and was debating if i should get new carpet and put it in or not... then it hit me bed liner on the interior.
Should i do this or is it a bad idea? has anyone heard of it done before and how did it work out? also if i get tired of it could i get it up?
  #2 (permalink)
Old 03-07-2010, 06:37 PM
2004460 2004460 is offline
2004460 is starting off with a positive reputation.
i did it to mine after i put floorpans in then put carpet over it idk how hard it would be to get off though i had ran around with ony the bed linner for a few weeks held up good
  #3 (permalink)
Old 03-07-2010, 06:53 PM
hp246 hp246 is offline
1976 Ford F-100
hp246 is starting off with a positive reputation.
I used bed liner on my floor. I was hoping it would turn out better than it did. I think its a good idea from a standpoint of protecting the floor. I was hoping it would have given me a bit of sound and heat insulation, but it didn't. On my list of things to do is to put down sound deadener and either carpet or rubber mat.
  #4 (permalink)
Old 03-07-2010, 07:53 PM
can you just put in sound deadener and carpet over bed liner?
and could i get a picture of it if you dont mind
  #5 (permalink)
Old 03-07-2010, 07:59 PM
1976 Ford F-100
Sure, soon as I get your check, I'll go out and buy the materials. You should have the pictures two weeks later.
  #6 (permalink)
Old 03-07-2010, 08:37 PM
75Three90's Avatar
75Three90 75Three90 is offline
1997 Ford F-250
75Three90 is gaining momentum as a positive member of FTE.75Three90 is gaining momentum as a positive member of FTE.
I'm doing the dash and all but I got the spray can stuff got
  #7 (permalink)
Old 03-08-2010, 02:14 PM
ChaseTruck754's Avatar
ChaseTruck754 ChaseTruck754 is offline
1974 Ford F-250
ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.ChaseTruck754 has a great reputation on FTE.
Quote:
What did you use to coat yours?
I am planning on doing both the inside and under side of the crew cab - both cab and bed!
__________________
Have you flown a ford lately?
1938 Ford Pickup = hot rod
1970 Ford F250
long bed & 1974 Ford F100 Supercab - 2wds
1974 Ford F250 4x4 Crew cab
thread in "motor swap" forum
1989 Ford Ranger= Never gonna be done...
1972 Alfa Romeo GTV & 1999 Toyota Tacoma 4wd = DD
  #8 (permalink)
Old 03-08-2010, 03:33 PM
Behemoth Behemoth is offline
Behemoth has a very good reputation on FTE.Behemoth has a very good reputation on FTE.Behemoth has a very good reputation on FTE.
I had my cab floor and back walls done in Line-X bed liner, and I think it came out pretty well. Granted, I had the entire interior sandblasted along with everything else on the truck, but I wanted to make sure it was going to stick, and we had to find all the rust to know how much of the floorpan to replace.
Anyway, here's a couple shots of the finished product (the floor, anyway.....Buford won't be on the road for a few months yet).
Click the image to open in full size.
  #9 (permalink)
Old 03-08-2010, 05:19 PM
TheDesertRat TheDesertRat is offline
TheDesertRat is starting off with a positive reputation.
I did my entire interior of a 76 Blazer in Line-X and really like it. You can either leave it as is, which I did since I off-road it almost exclusively, or you can just cover it back over with the jute padding/carpet setup like a stock rig.
  #10 (permalink)
Old 03-08-2010, 05:39 PM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
Post when I get chance
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
I also coated mine inside and underneath with Rhino Lining. I still placed carpet inside. So far I'm loving it. Only downfall with Rhino lining the cab is making sure you run a good groundwire from the cab to chassis.
__________________
1977 F250 4x4 Highboy
521 Stroker D44/60 C6
  #11 (permalink)
Old 03-08-2010, 05:44 PM
fatdan460's Avatar
fatdan460 fatdan460 is offline
1985 american sex machine
fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.fatdan460 has a great reputation on FTE.
a company called durabak make a liner in two varieties and a ton of colors. you can get smooth or textured. so you could do the whole interior if you wanted
__________________
Quote:
Originally Posted by alpha/omega View Post
His brain wouldnt function under what you would call "normal" conditions. Dan is truely one of a kind. Too weird to live and too rare to die.
your post per day average may be 2.03 but your lols per day far exceed any one else on FTE hands down.
  #12 (permalink)
Old 03-08-2010, 07:46 PM
cool thanks for all the help and input
  #13 (permalink)
Old 03-08-2010, 10:35 PM
460/5's Avatar
460/5 460/5 is offline
Zombie Survivalist
460/5 is a name known to all460/5 is a name known to all460/5 is a name known to all460/5 is a name known to all460/5 is a name known to all460/5 is a name known to all
i was plannin on rhinolinin the floors of my trucks. im wonderin how well it would work to do it over the top of some dynamat or somethin like that...
__________________
Brother Trey- Slackmaster #18
Why I'm called "Brother" Trey- http://www.youtube.com/watch?v=F5h0g...eature=related
'93 Explorer, Eddie Bauer, 4.0, 5 speed (converted), 4x4, 31x10.5 tires.
'84 F250 XL, blue, super cab, long bed w/ 6.9 IDI, T19, 4x4.
  #14 (permalink)
Old 03-08-2010, 10:55 PM
fatdan460's Avatar
i dont think that would work out to well but you could do the underside of the cab (i know that it would kinda be a pain in the *** while its still on the truck)and multiple coats in the cab and that would help with sound deadening and keeping heat in/out
__________________
  #15 (permalink)
Old 03-08-2010, 10:56 PM
460/5's Avatar
Zombie Survivalist
well, when i go to deadenin the truck, itll be a frame-off resto, so ill be able to paint whatever i want. lol.
__________________
Tags
1999, bed, bedliner, cab, ford, frame, inside, interior, liner, linner, put, replace, ryno, spray, spraying, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
