rpm gauge installation 1985 f150 4 speed manual
hi I am trying to install a rpm gauge in my truck, I have the power, ground and dash light wires all attached, what I cant get is wear to hook up the wire that receives the tack signal, the truck did not have a stock tack and this is the first one that has ever (attempted) installed. any help is appreciated, pictures would be great
there is my engine (it is cleaner now)
I can get more pics no problem if more are needed.
yes the wire is green/yellow, the other one is brown.
do I just cut the green one expose the wire and splice in the green tack wire then solder and heat shrink tube and electrical tape.
the instructions say i then have to set the tack.
http://www.equus.com/Content/Support...-0012.revB.pdf
it is a 6 cylinder so do i set it to the 6 cylinder setting (3000 rpm) or am I setting it to the coil on plug (500rpm) or am i setting it to the 3rd option (I dont think it is this one so I wont bother)
it is on page 2 if you dont understand what I am asking.
thanks all so much, this is a big help.
