Squeaky Front Shock!!!!
Old 03-04-2010, 06:57 PM
jwillyf150's Avatar
jwillyf150
jwillyf150 is offline
Does anybody have any suggestions on how to stop a squeaking front shock. It's my drivers side front shock only. The shocks are fine as far as wear and ride, it's just this squeaking (very noticable in parking lots) thats about to drive me crazy!! Thanks for replies..
Old 03-04-2010, 08:45 PM
jwillyf150's Avatar
jwillyf150
Anybody???
Old 03-04-2010, 10:07 PM
Ryan50hrl's Avatar
Ryan50hrl
Ryan50hrl is offline
I think you'd have to replace the shock.....
Old 03-05-2010, 04:21 AM
magnet1's Avatar
magnet1
magnet1 is offline
I am glad to see I am not alone. I couldn't tell if it was my steering or suspension, But its definitely my shocks. I even went underneath and lubed all the rubber bushings with Kroil, Hoping it would solve the annoying noise; But its still there. I only have 34,000 on my truck, So I am not ready to put new shocks on yet.
Old 03-05-2010, 05:31 AM
shorebird's Avatar
shorebird
shorebird is offline
I do not believe that is is the shock. I would look at pivot points of the suspension as the source of the squeak. Have you had someone bounce the truck while parked and you listen to the area?
Old 03-06-2010, 07:16 PM
1BADGRL's Avatar
1BADGRL
1BADGRL is offline
I have an 06 F150 Supercrew... Changed the shocks at around 72k (Bilstiens) and I have the squeak you described. Its driving me crazy. Its NOT THE SHOCKS. If anyone has any ideas I'd love to hear them.
Old 03-06-2010, 07:18 PM
Ryan50hrl's Avatar
Ryan50hrl
sway bar bushings???
Old 03-06-2010, 07:26 PM
1BADGRL's Avatar
1BADGRL
1BADGRL is offline
Hmm... Will check it out. It's a really high pitched squeak like metal on metal. Almost sounds like it's coming from the hub.
Old 03-06-2010, 07:48 PM
NASSTY's Avatar
NASSTY
NASSTY is offline
Could be? Or maybe a tie rod end?
Old 03-06-2010, 09:29 PM
magnet1's Avatar
magnet1
magnet1 is offline
Yeah, I really notice mine when I am pulling out of the garage. When I put it in gear and step on the gas; Just before the truck moves it gives that "bathtub" squeak. That little bit of initial torque must effect the suspension somewhere. I know its not in the steering. It also does it when you have an extreme rise and drop in the road. I lubed every joint I could find, And still hear it.
Old 03-07-2010, 11:44 AM
jwillyf150's Avatar
jwillyf150
I have lubed everything also and it still squeaks a little just not as loud. It's really getting annoying.
Old 03-07-2010, 06:02 PM
wolf189's Avatar
wolf189
wolf189 is offline
Originally Posted by jwillyf150
Anybody???
ummm... turn the stereo up?
...that was what someone suggested to me once some years back when i was trying to figure out what to do about a similar mysterious creak coming from the front of the '93 F-150 I had at the time. never did figure it out before finally selling the truck. hopefully you have better luck than i did.
Old 03-07-2010, 06:45 PM
Smokey01's Avatar
Smokey01
Smokey01 is offline
I have ran into this problem before with the sqeeking....ball joints was my problem
Old 03-07-2010, 07:29 PM
NASSTY's Avatar
NASSTY
NASSTY is offline
How did you lube the non-greasable ball joints and tie rod ends?
Old 03-07-2010, 09:41 PM
jwillyf150's Avatar
jwillyf150
No but did notice a tear in the lower ball joint boot. The squeak kinda sounds like it may be coming from this location. Maybe I can shoot some grease in this cut for temporary fix dunno?
Quick Reply: Squeaky Front Shock!!!!
