Oil filter relocation kit
I haven't put one on, but i'm just kinda wondering why you'd want to. As it is, that filter is probably the easiest thing in the world to get to. But as for them working well, sure. There are tons of them out there and are used in just about every form of racing and/or towing. If you want/need one, I don't think there is much to worry about.
-=Whittey=-
-=Whittey=-
I would like to get one of these things for three reasons. Reason#1: I am short and I hate standing on the bumper to get to the filter. Reason#2: I hate removing the filter from the bottom because I allways manage to drop the thing and get oil all over the car port. Reason#3: My girlfriend & the land lord get pissed when I get oil all over the car port. So in other words I want to make this opperation as clean and trouble free as posible in order to simplify my life. Also please do not tell me to pay to have someone do an LOF for me.
Yeah you sure can get to it from the top. As a matter of fact it is easier to do it that way than from the bottom, mainly because the crossmember and the steering linkage get in the way (read: no good way to get the filter out from the bottom without dropping it.). I'm going to mount the filter right next to the to the windshield washer tank so I can convienlently reach it when I'm just itching to change my oil at some odd place and time. That is of course if one of y'all would tell me if the kit is worth a darn.
I dont think they cause problems, I've just never heard of one for a 300 but I guess they are out there. My friends 1990 chebbie S10 4x4 with the 4.3L V6 had a remote oil filter up by the headlight from the factory because a block mounted filter would hit the front driveshaft, he would always fill his filter up and crank it up with no problems.
I am planning on running remote filters both on my new engine, and the 300-6TT. But I am running the dual remotes, with a cooler. I am doing it just to get the dual filters, for higher flow, and better filtration. Be sure to mount it with the adaptor above the filter, so the filter hangs down, and also fill the filter before you install it. I would highly recomend using a Motorcraft filter, as they have a better anti-drainback valve.
Because there's still siphon pressure that could drain them at least partially, but all FL1A-equivalent filters have that valve built in.
You can get the parts you need from Jeg's (free shipping), Summit, or probably Ford Racing.
