Speedo Acting Up...What's My Problem?
Old 03-01-2010, 08:50 PM
motor-man's Avatar
motor-man
motor-man is offline
Hey guys.
So for about the past 3 weeks I have been putting up with my speedometer acting up. It will either...
1.) Not work what-so-ever.
2.) Try working but will be inacurate
3.) Work fine (20% of the time)
4.) Work fine, then stop working lets say at 80km/h and will stop. Next start up the truck will think that it is at zero (even though it's still at 80), so another 80km/h and it reads 160km/h.
Whats the problem here guys?
Thanks.
Old 03-01-2010, 09:34 PM
jboczar's Avatar
jboczar
jboczar is offline
more than likely you need a replacement instrument cluster. You could have your vehicle scanned for codes but if it doesn't generate any codes for either the cluster or the abs module then the cluster is bad. Try ebay or maybe a reputable you junkyard, you don't want to buy one from the dealership, they are very expensive.
Old 03-01-2010, 09:48 PM
motor-man's Avatar
motor-man
Thanks. A little over a week ago my ABS light came on. The next day about halfway to the dealership the light went out. I went anyways to see if there were still codes and get them checked out. The tech said there was a code for the driver front ABS, and some kind of code that required some kind of new flash (not exactly sure). After he cleared the codes, the light has not come back on, but the speedo was still whacky.
Old 03-01-2010, 09:59 PM
bismic's Avatar
bismic
bismic is online now
Received 2,494 Likes on 1,731 Posts
I have read that sometimes turning your lights on and disconnecting your batteries will correct the problem for a period of time. Might be worh a try while you look for good pricing on the parts.
Tanbeard
05-23-2013 01:02 PM
shia1
1978 - 1996 Big Bronco
05-26-2009 04:32 AM
advocate
1997 - 2003 F150
30
12-24-2008 11:59 AM
jason1
1983 - 2012 Ranger & B-Series
11-18-2008 06:03 PM
Manwith3fords
18
02-29-2004 04:34 PM
Quick Reply: Speedo Acting Up...What's My Problem?
