Speedo Acting Up...What's My Problem?
Hey guys.
So for about the past 3 weeks I have been putting up with my speedometer acting up. It will either... 1.) Not work what-so-ever. 2.) Try working but will be inacurate 3.) Work fine (20% of the time) 4.) Work fine, then stop working lets say at 80km/h and will stop. Next start up the truck will think that it is at zero (even though it's still at 80), so another 80km/h and it reads 160km/h. Whats the problem here guys? Thanks. |
more than likely you need a replacement instrument cluster. You could have your vehicle scanned for codes but if it doesn't generate any codes for either the cluster or the abs module then the cluster is bad. Try ebay or maybe a reputable you junkyard, you don't want to buy one from the dealership, they are very expensive.
Originally Posted by jboczar
(Post 8583725)
I have read that sometimes turning your lights on and disconnecting your batteries will correct the problem for a period of time. Might be worh a try while you look for good pricing on the parts.
