Need help with my 347 supercharged F-250
Old 02-27-2010, 12:28 PM
ASG 89 F-250's Avatar
ASG 89 F-250
ASG 89 F-250 is offline
I can't get my motor to run right it smells like its getting too much gas. I was wondering if anyone had ideas what to do. I'll try list all the info i can about my truck.
1989 F-250 4x4 AOD Transmission
347ci. D&D Motorsports Inc. Long Block
TFS heads
10:32 compression
stock intake manifold with 1.5in spacer
42lb. injectors
ford racing wiring harness ecu and mass air flow sensor
powerdyne 7psi supercharger
Old 02-27-2010, 11:19 PM
lmd91343's Avatar
lmd91343
lmd91343 is offline
What size MAF sensor?
Old 02-28-2010, 08:16 AM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
How is it tuned, is it a chip or Tweecer? If it's a chip, make sure it's still seated in the PCM.
Old 02-28-2010, 09:02 AM
Conanski's Avatar
Conanski
Conanski is offline
Yeah... that's gonna need a tune to run anywhere close to half decent.
Old 02-28-2010, 04:14 PM
ASG 89 F-250
I don't know what size MAF sensor. It came with the wire harness kit the part # is FMS M-12071-A50. I got it from Summit Racing Equipment.
I have no chip in it. Its just the ECU that came with the wire harness kit.
Old 02-28-2010, 05:06 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,173 Likes on 927 Posts
I agree with Paul, that setup is going to need a custom tune. The ECU that came with that kit was not calibrated for all mods you have.
Old 03-01-2010, 05:34 PM
ASG 89 F-250
There are no tuning shops in my area. So what do I do?
Old 03-01-2010, 05:50 PM
rla2005's Avatar
rla2005
rla2005 is offline
Get a Tweecer or Moates Quarterhorse and start reading. Paul Conanski installed a wide-band O2 sensor to monitor his air/fuel ratio. You will need something similar to keep that beast of yours alive. It's going to be a steep learning curve if you can't find a shop to trailer that thing to or buddy up with someone familiar with the tuners listed above.
Old 03-01-2010, 07:13 PM
79 f-150 guy's Avatar
79 f-150 guy
79 f-150 guy is offline
truck sounds badass, got any pics??
Old 03-02-2010, 07:59 AM
Bob Gervais
Where are you located?
Old 03-02-2010, 10:38 AM
DJdemon6696's Avatar
DJdemon6696
DJdemon6696 is offline
X2
get a tweecer
Old 03-02-2010, 01:08 PM
86F150302's Avatar
86F150302
86F150302 is offline
Going to need a Wideband and tweecer or quarterhorse like stated above.
Old 03-09-2010, 05:58 PM
ASG 89 F-250
Ok i got a Tweecer Rt going to read up on using it.
I will try to get some pics soon.
I live near Ashland, Wisconsin.
Thanks for helping guys i never knew about Tweecer tuners.
Old 03-09-2010, 09:20 PM
79 f-150 guy
ya pics, sounds badass..
Old 03-11-2010, 05:29 PM
ASG 89 F-250
I've been working on it for a few years now. Stripped it down to the frame and repainted it. did a little body work on the front end and put 2004 range rover lights in it. Need to get some paint touched up on the hood then I will get some pics.
