ZF manual trans 6 speed fluid, what are you using?
I'm not saying you're wrong. I'm just wondering what changed in the ZF-6 between yours and mine. Was there some internal modification, or did they find out atf didn't work as well? I've got over 320k on my ZF-6 running ATF with no issues.
Sold...staying with standard Merc V in my 2000 ZF when I change out fluids this spring. No issues at 320K miles speaks volumes.
Also for years I have been running 10w-30 in my chrysler 5-speed which originally called for ATF with a huge increase in performance and feel.
If i were to guess they probably chose atf over gear oil as it was a thinner fluid less likely to cake up from heat and yet stay thin in the extreme cold. Other than that there is no hydraulic system in a manual trans , just gears spinning, so I highly doubt it matters so much as to what u use.
My only concern would be chemical compounds and their reaction to internal components. IE... you do not want to add a fluid type that is corrosive to brass etc. last I heard regular 10w30 didn't eat anything but certain synthetics may. I would stick with fords brand
I recently switched to "Valvoline Maxlife Dex/Merc ATF " . It is fully synthetic and its compatibility statement says:
Recommended for use where DEXRON, DEXRON II, III and VI, Toyota T-IV and WS, MERCON®, MERCON® SP and LV, Allison TES 389, Nissan Matic-D, Matic-J and Matic-K, Honda Z-1 (except CVT), Mercedes NAG-1, Mitsubishi Diamond SP-II and SP-III and many others are required.
I got mine at Walmart (6 qts. for ZF6 ) .
#28
Guess I can update to. 510,000 miles now and I've started substituting in 1 qt of MTF for the fluid and just mixing it with the ATF. Seems to help some of the shifts when going over bumps so it doesn't grind as much.
Still change the fluid every 50k, still comes out looking clean, still running the factory transmission with no rebuilt parts.
