Colorado Chapter Join Chapter, Leader:
Where to get frion?
Old 01-21-2003, 01:07 AM
dassmoof's Avatar
dassmoof
dassmoof is offline
Where to get frion?
I need some to get my compresser running so my damned windows wont fog up when I turn the heat on
Old 01-21-2003, 07:40 AM
Yelrisheam's Avatar
Yelrisheam
Yelrisheam is offline
Where to get frion?
You can't get freon anymore over the counter. I believe the only way you can get it now is if you have at least a spec. 6 (automotive) A/C certification. If you need to get the compressor running, there's a low pressure switch that will shut the compressor down if the freon load is to low. This prevents the compressor from cycling and buring itself up. However, it is an extremely bad idea to run the compressor without the gas, for this same reason.
Old 01-21-2003, 11:44 AM
dassmoof's Avatar
dassmoof
dassmoof is offline
Where to get frion?
I can't just take it to Grease Monkey or something and have them dump it on in?
Old 01-22-2003, 08:19 AM
Paarrothead's Avatar
Paarrothead
Paarrothead is offline
Where to get frion?
What year is your truck?
Does it use R-12 or the newer stuff?
Old 01-27-2003, 02:13 PM
Mike G's Avatar
Mike G
Mike G is offline
Where to get frion?
The R-12 needs to be done by a facility. WalMart has a conversion kit for about $30 but I do not know if you will need additional cans of charge for the complete system. By '92 need to have the R-12 charge and rumor has it that runs $100. There is a place by I-25 and DTC that came recommended for the job but I can't recall the name now...
--Mike G
cory5517
05-25-2016 10:20 PM
azelkster
13
03-01-2016 11:05 AM
bigb56
03-16-2015 08:05 PM
Slimsadie
05-03-2010 11:26 AM
shess62
10-01-2003 11:15 PM
Quick Reply: Where to get frion?
