Dim dash lights
You might also be able to switch to brighter bulbs.
If that still doesn't suit you,then you can try painting the gauges white or a similar color.
https://www.ford-trucks.com/forums/7...te-gauges.html
You can remove the clear bulbs and covers as Shaun recommends, but replace them with blue colored 194 bulbs. They're available at just about any parts store and make a noticible difference. I also got a huge difference on mine when I had to replace my light switch. I don't recommend replacing the switch just to make your dash bulbs brighter, but maybe cleaning it might get the same gain I realised with mine.
Thanks Guy's for all the advise. I've been busy the last few days & forgot to check the post again & I didn't get any email notifications telling me you'll had posted.
I really don't care about the green look so blue or green bulbs don't really matter to me.
How hard is it to take the cluster out & disassemble the dash & take the covers off?
How many bulbs do's it take? I also might replace them with the 168's so there brighter.
Mine were the same - you could tell the dash lights were on, but that was all - I thought half of them must have been blown, but they were all working.
I removed the blue covers & renewed all the bulbs, also the ashtray & wiper/light switch bulbs.
Made a huge difference - one more job off the list
I removed the blue caps yesterday. Man what a difference!
I will say though, last night I sat down & read the thread about painting your gauges white & I'm seriously thinking about painting them silver because I love that look! How hard is it to change everything to the red bulb look?
I did a slightly different mod with the LEDs, instead of taking out the blue sheaths, I just purchased these ::
I will say the difference is impressive, about 4-5 times more brilliance, and the bluish green is like a nice medium blue. I found that when replacing some of the bulbs since the contacts are so old I had to use a cleaner otherwise the bulbs appeared to be bad - also these bulbs have cheap contacts so you have to fiddle with them in the sockets for a minute, but the final result was
Amazon.com: Zone Tech 10x 194 168 2825 5-smd White High Power SUPER BRIGHT LED Car Lights Bulb: Automotive
