1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
V10 Spark Plug Blowout!!
Old 03-07-2010, 05:35 PM
twall_SD250's Avatar
twall_SD250
twall_SD250 is offline
Hey RentAMan i got a question for you i have a post under this section and the modular 4.6/5.4L . It says "PLEASE HELP CRACKED EXHAUST MANIFOLD".... Can u take a look at it read it and let me know if u have any input for me
thanks
Old 03-07-2010, 05:39 PM
RentAMan's Avatar
RentAMan
RentAMan is offline
Talking
Sounds like he is giving you a guarantee that it will never go bad.
Let him have at it, if you want it done.
Just remember, you get one try to do it.
You haven't lost anything by trying it.
If it gives you problems afterwards, there really isn't any fixing it.
Old 07-27-2014, 08:11 PM
Todd Wenke's Avatar
Todd Wenke
Todd Wenke is offline
Heli coils work great for me so long as they are installed properly. A little anti-seize goes along way to avoiding plug problems
Old 07-28-2014, 08:23 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
for 50 bucks, I would go for it.
no one really answered "why do these blow out" questions.......the root cause is compression build up due to carbon build up and the point of failure is the spark plug threads. run some carbon cleaner once in a while.
Old 07-28-2014, 08:42 AM
Tom's Avatar
Tom
Tom is online now
Originally Posted by speakerfritz
for 50 bucks, I would go for it. no one really answered "why do these blow out" questions.......the root cause is compression build up due to carbon build up and the point of failure is the spark plug threads. run some carbon cleaner once in a while.
Now that's a theory I've never heard before. Can you explain to the class how carbon buildup would cause the threads to fail?
Old 07-28-2014, 09:20 AM
Big-Foot's Avatar
Big-Foot
Big-Foot is offline
While I don't believe that the decrease in combustion chamber volume and the increase in net compression ratio would "cause" a plug to blow out - it is known that combustion chamber deposits can cause detonation / pre-ignition and the resulting pressure increases are known to be extreme and could contribute to the failure of the threads..
Old 07-28-2014, 06:19 PM
Cardinal Puller's Avatar
Cardinal Puller
Cardinal Puller is offline
Get a used timesert kit from ebay. You can resell it for little loss. That's what I did, did all 10 inserts, resold the kit. My post on this is in the V10 section.
Old 07-28-2014, 06:34 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
When using a heli-coil you run the risk of it blowing out with the plug. In some cases it damages the head beyond repair. Ive seen it many times on 4.6L cars.
Also this thread is 4 years old
Kdr358's Avatar
Kdr358
Kdr358 is offline
Old 07-28-2014, 06:37 PM
Kdr358's Avatar
Kdr358
Kdr358 is offline
Old 07-28-2014, 07:34 PM
EXv10's Avatar
EXv10
EXv10 is offline
They blow out from plugs being too tight or too loose and heli-coils have a BAD reputation. They can't just blow out from high pressure or the top fuelers' would blow all eight every time. Not detonation either.
Old 09-18-2014, 11:30 PM
Todd Wenke's Avatar
Todd Wenke
Don't pull the plugs hot, wait till they cool down.
  #28
Old 09-19-2014, 05:15 AM
redford's Avatar
redford
redford is offline
Received 1,565 Likes on 913 Posts
Welcome to FTE, Todd. I have seen a lot of opinions, both from Ford and from reputable certified mechanics, on how to pull a spark plug from the 2V and 3V 4.6, 5.4 and 6.8L Modular engines. It seems that all they can agree on is that these engines present a challenge.
Josh Ludwig
46
04-09-2023 12:32 PM
_Rick_
55
07-19-2015 10:28 AM
klr650goldwing
Modular V10 (6.8l)
03-15-2011 11:24 PM
T18skyguy
Modular V10 (6.8l)
01-14-2008 05:20 PM
Quick Reply: V10 Spark Plug Blowout!!
