more VIN numbers
#318
Too funny. The VIN you typed in became a link to the VIN decoder with your info. Try just clicking on your own VIN link. Looks accurate to me, but ??
Or this link might also work.
VIN Decoder - Ford Truck Enthusiasts Forums
You posted your question in the 1961-1963 Ford Unibody section.
#319
#320
66595 =Serial number
A= load rating
4662522-L
4= Ford V8
66 =Unibody
25= F250
22= 122 In WB
L= Left Hand Drive
Trim 202 sorry nothing on that one, 1 might be Standard cab, 2 Delux cab
1TT= Sultana Turquiose
Axle Ration 4.56:1
Series F-F250
GVW 5400 Lbs
R= engine 292?
4 Spd manual trans
Most of this information is hit and miss, this is what I have managed to collect so far. Heck have more questions than answers, what engine?
#321
Thanks, spot on.
And it is indeed the 292. The door has custom cab written on it. Perhaps that is the trim code?
66595A
A= load rating
4662522-L
4= Ford V8
66 =Unibody
25= F250
22= 122 In WB
L= Left Hand Drive
Axle Ration 4.56:1
Series F-F250
GVW 5400 Lbs
R= engine 292?
4 Spd manual trans
A= load rating
4662522-L
4= Ford V8
66 =Unibody
25= F250
22= 122 In WB
L= Left Hand Drive
Axle Ration 4.56:1
Series F-F250
GVW 5400 Lbs
R= engine 292?
4 Spd manual trans
#324
You posted this question in the wrong forum, this is for 1961/63 Ford F100/250 Uni pickups.
Ask further questions in the 1968/2013 Full Sized Van (Econoline) forum.
E38 = E350 Cut-Away.
A = 460 4V
H = Lorain OH Assembly Plant.
BA2110 = 1978.
Cut-Away: FoMoCo cuts the Econoline van body off behind the front seats so that aftermarket body makers can install a box van, people mover, ambulance and etc bodies.
Cut-Away also used for Class C motor home bodies.
Line 3: E250/350 Cut Away Cab =
#328
F10 = F100 2WD
J = 223 1V I-6.
K = Kansas City MO Assembly Plant.
155713 = 1961, assembled March 1961.
1096 = Domestic Special Order number, your truck was special ordered by the original purchaser, not "bought off the lot."
Look on the Warranty Plate, is there a COLOR code, or is it blank?
#330
Domestic Special Order: 4 digit DSO:
Some type of special equipment was installed on the truck after it left the assembly line that was not an RPO (Regular Production Order).
Or if the truck was ordered with a non standard color, there would be no COLOR code stamped on the Warranty Plate.
Special equipment could be a 4WD conversion. Or some sort of "back of cab" equipment like a Utility Bed, for an example. But obviously this wouldn't apply to a Uni.
*It could also be the A/C that this truck has.
The problem is, there is no way to discover what type of special equipment was installed, because the IDIOTS at FoMoCo THREW AWAY all the records decades ago!
