67 300 Econoline headers?
Old 02-23-2010, 03:18 PM
timvreug's Avatar
timvreug
timvreug is offline
Has anyone seen or heard of putting headers on a 300 - 6 in a '67 Econo? I have a falcon super van that has a newer 300, and I'm in the process of MFI'ing it to an '89 4.9 system, only problem is that the 4.9 MFI exhaust won't fit in the doghouse, and I don't want to mess with blocking the old manifold riser.....
Hedman makes the 89300 headers for the truck, which I believe uses the same crossmember to mount the engine, but they have not had one in to fit check to see if it would work. I know it shouldn't work on the older econo's, as they mounted engine differently, but the '67 just might. Any help would be appreciated.
Old 02-24-2010, 07:35 AM
jschira's Avatar
jschira
jschira is offline
Clifford Performance/Research makes a ton of stuff for Ford 6 cylinders. Everyone that I know that has hopped up a 60s Ford 6 cylinder has used at least some Clifford products. I do not know how much of it will work on an E-100, but they can probably tell you.
Here is a link tho their catalog page for the Ford 300.
Clifford Performance: Ford 300 & 223
Old 02-24-2010, 04:08 PM
timvreug's Avatar
timvreug
timvreug is offline
Thanks! I called Clifford and they confirmed it will work! I assume that will make all the truck headers to fit the '67 -300. So many have just never done it, as everyone wants to jam a V-8 in the hole!
Old 12-10-2011, 06:03 PM
marcgyver77's Avatar
marcgyver77
marcgyver77 is offline
Did you find headers to fit?
I have the same question and wanted to know if the Hedman headers from a 240 F100 would fit?
Old 12-10-2011, 08:21 PM
timvreug's Avatar
timvreug
timvreug is offline
I think Clifford is the only one that will fit. I ordered the Hedman and they did not fit. they stuck out of the doghouse as well. I made a blocker for the old manifold, and went that way.
Old 12-10-2011, 10:17 PM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
The EFI manifolds that are split, will be an improvement....
Headers are useless on a stock engine.....The EFI mani's will give a definantly power boost....
Old 12-12-2011, 01:07 PM
Ruffinit's Avatar
Ruffinit
Ruffinit is offline
I used the Cliffords when I replaced the old 3:2 dual headers on my E100 p'up 170ci. The difference in torque and throttle response was quite evident. The 6:1 is a great way to go.
Though I haven't put headers on my '66 Falcon van, it has a 240 in it which is the same block as a 300 so you should be able to make that work. Give them a call they will KNOW. No guessing required.
vjsimone
12-28-2018 08:34 AM
krewlstang
1999 to 2016 Super Duty
02-28-2015 11:01 AM
Lars326
13
07-18-2014 11:24 AM
whereiskrazydave
10-28-2013 08:14 AM
Quick Reply: 67 300 Econoline headers?
