Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Split-rim wheels vs Budd wheels
Old 02-24-2010, 10:51 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
Marmon-Herrington Man
Here's the thread from the Stovebolt site where one of the guys found a set for his Chevy. It's got another F-7/8 wheel pictured too. Good reading. Stu
Budd to Dayton wheel adapters - The Stovebolt Forums
Old 05-11-2011, 10:11 AM
Busguy71's Avatar
Busguy71
Busguy71 is offline
Anyone know where you can buy the tools to dismount/mount tires on the three piece 20' Ford wheels? Google isnt helping, I have a good set of tires to put on my F8 but just need the tools to put them on!
Old 05-11-2011, 11:00 AM
rb48f6's Avatar
rb48f6
rb48f6 is offline
I looked on EBay - where I got the Ken Tool "pork chops". As for tire irons I did a search for Ken Tool tire irons and found a place with in easy drive and picked them up in person. Here's a link to the Ken Tool site, once you have a part number it helps narrow search results: Ken Tool - A Leader in Automotive Aftermarket Tire Repair Tools
Bought mine from here, Meyer location Livonia MI:
Tire Tools, Supplies and Changers from Myers Tire Supply
And here are a couple other sites:
Annco: http://www.annco.com/products/pro_1....e=Tire Service
Esco:
Equipment Supply Company
All Tire Supply:
Ken-Tool 37" Heavy Duty Tire Lock Ring Tool (T48A): All Tire Supply Company
And not enough CAUTION can be stressed in handling the multi-piece tires / wheels. There are a number of articles posted by Truck Dog and others as well as me on this site on precautions. Have you found and read them? In one post we pasted a link to the OSHA site that walked you through the process with pics. When filling - AIR SLOWLY something like 5# increments with wheels in a cage or well chained to keep pcs together in several spots.
Hope this helps
Old 05-11-2011, 11:17 AM
truckdog62563
Old 05-11-2011, 11:20 AM
rb48f6's Avatar
rb48f6
rb48f6 is offline
Busguy / and all multi-piece rim owners~
Here are links to .pdf files on the OSHA literature on wheel demount / mount and rim matching:
Demount / Mount:\
http://www.tireindustry.org/pdf/osha_Demount-Mount.pdf
Rim Matching:
http://www.tireindustry.org/pdf/osha_Rim%20Matching.pdf
Old 05-11-2011, 11:23 AM
rb48f6's Avatar
rb48f6
rb48f6 is offline
Ahh I see you beat me to it Stu. I originally posted without and thought better of it and went and found the links to add in too.
Now out to cut the grass before the next deluge comes through....
Old 05-19-2011, 11:05 PM
OldBlueOvalDude's Avatar
OldBlueOvalDude
OldBlueOvalDude is offline
The Dayton style wheel/hub system is more desireable for heavy haul and off road heavy hauling, such as forestry or construction applications. Budd's tend to crack from hole to hole in such applications. One thing nobody mentioned about the Budd's- the inner and outer nut on the rear duals can be a major P.I.T.A. It is not unusual for the inner nut to spin off with the outer during removal, and then the hotwrench is usually the only way to seperate them. I.M.H.O.,the modern hub piloted Budd type wheels with single nuts are the only way to go, but whether the appropriate hub is available for these older trucks may be another matter.
Old 05-20-2011, 05:24 AM
truckdog62563
As I've read, back in the day there apparently was a west coast bias toward Dayton style wheels and an east coast bias toward disc style (Budd, K-H, Motor Wheel, Firestone/Accuride). Perhaps one reason was your comment about load capacity of Daytons. No doubt the loads limits out west back then were much higher than in the east.
The hub piloted system has been in use, with essentially no change, since the 1930s. Motor Wheel Corporation pioneered the system which was used predominantly by GM and, by extension, REO. The limiting factors today are, like you said, the lack of alternatives for obsolete bolt patterns. More commonly today, it seems we see guys with Studebakers, GMCs, and '60s era medium duty Fords who have to convert their hub piloted trucks to stud piloted mountings to eliminate their widow maker style wheels. Stu
Old 05-22-2011, 11:42 AM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
subscribing.
Firechiefford
1947 and Older Ford Trucks
45
11-06-2015 12:47 PM
Caleb H
10-16-2015 04:42 PM
twinzilla
WTB - Parts & other
02-23-2014 02:12 AM
dmanlyr
Large Truck
02-03-2013 01:01 PM
48f6
40
02-18-2008 10:14 AM
Quick Reply: Split-rim wheels vs Budd wheels
