Anyone have a pic of where the fender meets the cab?
I am building a 1950 f1 and am trying to get the fenders fit to the cab. I cannot get them to fit without a gap.
Does anyone have some close up pictures of where the fender meets the cab. I would like to see the area on the top under the hood.
Thanks!
Dustin Winkle
Boise, ID
dustinwinkle@yahoo.com
Thanks!
Dustin Winkle
Boise, ID
I don't have a detailed picture handy right now but there is a gap there per the design, do you have the rubber filler moulding piece that goes there?
I'm sure someone here can explain it better than me and or have some pictures that may help.
good luck
Josh
edit, Ok maybe I do have some pictures this first one is a 52 but you can see the rubber (or whats left of it)
and a 51 harder to see the gap but it's there.
good luck
Josh
Hi Dustin and Welcome to FTE!
There is a thick (like at about 1/2 inch) soft rubber welting that goes in there as Josh mentioned.
I have a full front tilt but still have the welt on the fenders. It's thick enough to fill that gap even on mine - and th efenders aren't even bolted on! Here's a couple of pictures:
Here's a pic of mine, its not a very close up pic but if you look you can tell there is a gap between the fender and the cab.
When I put the front clip on, like you, I thought "Holy Cow!"
I asked a few questions here and found out that it was normal. One side of my truck is approx 7/16" and the other is maybe 3/8". As the others have mentioned there is a piece of welting that goes in there and fills the space.
Bobby
Bobby
Bobby
Thanks for the replies!
I am getting the gap on the top of the fender between the cab and the fender. You can only see this area when the hood is open. The gap is about 2 inches. I am not sure if it is supposed to be this way, or if I am not putting it on correctly.
Are you talking about the area where the fender/inner fender come together at the cab right below the hood hinge? There is quite a big gap there between the top of the fender and the cab, the inner fender curves outward where it meets the fender but 2" sounds a bit excessive. I found these pics, I can't say for sure but it looks like something in the area of an inch or so. I can measure when I get home this evening.
Bobby
Bobby
