what is the largest spare tire that will fit in the stock location? I have a spare 315/70/17 tire laying around and I would like to use it but don't want to mount it in the bed...
Wow! That is a good question. Tire to close to the exhaust how great of a hazard is that, I know once a tire is on fire, its intense, but could it really be ignited?
From experience elsewhere; the tire will heat up and crack and harden, but not actually blow. the spare is still useable in said shape (well, *I* used it), but not for any kind of real distance.
I need to get a 35" spare under mine. It would be a pain to swap a front to the back if I blew out a back tire (limited slip differential). Plus I don't even have lug nuts for the factory spare, my wheels use the tapered style. The insulated wrap is a good idea.
I had a 35" under my 04 f350 diesel, but I had to remove a little bolt on L-bracket that was meant to keep it off the exhaust.
I have a 34" under my 09 f250 v-10 without having to modify anything.
