solid pipe to the 6637? anyone?
has anyone came up with a way to run a solid pipe from the turbo reduction boot to the 6637. i thought a 4" flex pipe from a semi would work, but the final bend was to sharp. i think it would look alot better than the 2 pup pieces and would let a little more whistle out. surely someone has figured this out.
for those of us with an aftermarket turbo that has the adapter to it, could we just run a piece of piping from that to the filter? what about making the tube shorter? would there be any adverse effects from shortening the tube and putting the filter on a straight light with the turbo intake?
sorry for the semi hi-jack
I'm assuming you have an early 99, here's a kit put together by Clay that incorperates that bend in the pipe, nice kit, no guessing . Riffraff Diesel: RDP 6637 Filter Kit
I was all set to order this kit from Clay, but there's not a pic of the pipe with the bend, and i wwant to make sure this kit will delete the factory accordian hose that Clay gave me at RRE2009...Clay, chime in if you want...
I think and I gather worm is talking about a pipe after the turbo intake pipe, sorta like deleting his CCV, running a 4 inch pipe from there then the bend to his filter choice? Not sure I ever seen a straight thru pipe, deleting that accordian style stock tube, unless you go with an upgraded turbo.. [quote] for those of us with an aftermarket turbo that has the adapter to it, could we just run a piece of piping from that to the filter? what about making the tube shorter? would there be any adverse effects from shortening the tube and putting the filter on a straight light with the turbo intake? [quote]
Custom maybe 2000ca250
does not work it is now big deal your not out a lot of $$
on
start with this comming off of the turbo...
Bending Reducer
comes in black as well
then go to Pipe strait to the filter..less clamps..less splices..cleaner look...
http://intakehoses.com/Merchant2/mer...gory_Code=MIE0
aluminum tubing is far better then exhaust pipe..aluminum tubing doesnt hold heat like exhaust pipe does..and the one I posted is used on a PSD...
Bending Reducer
