Buzz noise
Buzz noise
So I get up on a cold humid morning in reno and turn my truck on to discover a buzz noise when the GPR engages. Started the truck to find out it is taking a little more cranking time to fire. so a week goes by and the buzz is still there and now when i try to start the truck it will not start. Replaced the relay and still does the noise and now my batteries are drained. Any ideas? FYI '97 F250 PSD
well did the battery cleaning and the buzz is still there so i did a resistance check and found out all my plugs have 8 ohms of resistance. what does this mean? do i change my plugs or is it something in the UV harness? Also i noticed while checking the grounds on the engine from the batts, that the ground strap from the engine to the frame isn't there. is this something i need?
yellowmatter
12-01-2006 05:43 PM
