Scangauge or AE?
Scangauge or AE?
Trying to decide which one I want to get.
AE- more portable (not permanently mounted in the truck), a little more capability, but you have to drag the laptop out to do anything. Easy to swap to a different rig to pull codes etc.
Scangauge- needs to be mounted... quad pod or steering column pod? gives you 2 more parameters to monitor in the cab, not quite as capable as AE (data logging) and can't move it to another rig as easily.
Thoughts/suggestions?
Depends what you want to do, Chase. For me, it was a no-brainer. I was contemplating an HPOP pressure gauge and an oil temp gauge. By the time you buy those two, you can buy the Scan Gauge. I can now monitor the most important parameters of my truck compeltely (especially if you add a fuel pressure gauge). I may still buy AE, just because I want to do a little more with my truck and want to be able to data log.
Get the best of both worlds with a DashDaq! The functionality of AE in a tiny little box that you can customize as much or as little as you want.
DashDAQ - Features
DashDAQ - Features
DashDAQ - Features
DashDAQ - Features
Does it offer injector buzz tests or cylinder cont tests? Can you recallabrate for larger tires?
I see you can data log, does it have the ability to e-mail these?
DashDAQ - Features
DashDAQ - Features
Hmmmm, I only spent 5 minutes on the website but I saw ICP, duty cycle, Cyl Rot Velocity, etc listed on the parameter list:
Dashdaq - Ford Data List
Have to do more homework on this box, but the initial look makes me think it is an option. Would like to hear about some personal experiences with a PSD.
I never would've been able to see that my HPOP was dropping too much before, and is good now with the hybrids, for example without ScanGauge. Yes, that can be done with AE, but it is really nice to be able to see all that stuff "on demand" without having to screw with a laptop. My $0.02.
It's definitely worth the ~$250 or whatever it is -- but if you want the full enchilada, then AE is it.
BTW, since it monitors trans temp, you can trade off a dedicated gauge for that and put the SG in its place. It's not like Boost or EGTs where they change in seconds -- you can set the gauge to cycle through 8 things (four screens of two different items each). You can also watch your battery Voltage and know when your GPs are working, taking the place of wiring up a separate LED. I was going to do that mod, but since I started watching my Volts, it's no longer needed.
