460 Horsepower Q's
460 Horsepower Q's
So what does a stock FUEL INJECTED 460 from an '88 F-350 have for horsepower/torque?
I heard it was around 230.. is that right?
Also heard that the cones in the intake restrict it, I could see that being true. Cutting those will give a few right?
Thinking of throwing on some shortyheaders, found on craigslist and managed to talk the guy down to $40 lol. Any idea on a gain over the stock manifolds?
The catalytic converter isn't on the truck anymore. Just straight pipes, is this a horsepower gain?
The smog pump is also not existant, it was removed and a shorter belt put on the engine. Its running a mechanical fan, but thinking of running electric.
And finally, what kind of gain could I see out of a cheap camshaft upgrade?
Thanks!
Thanks!
Without putting my truck on a dyno I don't really have #s, but here is what I've tried so far. Single 3" catback exhaust (my truck already had this when I bought it, but a family member did this to an otherwise stock '96) feels like 20hp. A K&N FIPK felt like a 10hp loss when I took it off and went back to the stock airbox because of the noise. Electric fans felt like a 5hp loss or a 15hp loss when I dumped them depending on the fan clutch being locked up or not, the electrics didn't cool enough for a tow rig. I had a catalytic converter fail so I gutted it, that might have gained a couple of hp but mostly it just sounded loud and crappy. When I installed a new converter I don't think I lost anything over the gutted unit. Hedman smog legal headers are the best mod I've done so far, they feel like at least +40hp over the manifolds with no other changes and I've heard that the Banks or Thorley Tri-Ys are even better (just more $$). I've got a set of F3TE heads (rebuilt, ported and milled .025") and a custom cam waiting for install and I'm looking for a 3 1/2" or 4" catback setup (a stock diesel tailpipe is what I'd like to find..) to finish this thing off. I'll post results when the rest of the stuff is done.
I don't like a noisy truck, if your willing to live with the racket then the K&N FIPK is a good mod, and replacing the cat with a pipe might help also. I just don't want to listen to the noise when I've got the family in the truck and we are on vacation.
The problems I had with the electric fans were only in worst case conditions. Towing (a small load) in 100+ deg conditions up a steep hill where I gotta go almost wide open to hold second gear-35 mph. With the stock setup, I can pull it into first and hold 2800-3000 rpm and crawl up the hill, the fan clutch locks and everything stays cool. With the electric it's running at full speed and just doesn't move enough air when crawling. Something else I noticed in driving around town was that when the truck started getting hot I could hear the electrics spin up to max, and the temps would stop climbing and come back down very slowly. With the stock stuff, when it gets hot and the fan clutch locks up the temps come down right away. Usually the clutch is locked up for maybe 2 minutes before the truck is cooled off and the clutch unlocks.
Wow, thats a long answer to a short question.. Bottom line is electric fans are probably great if you don't tow. But don't throw the stock stuff away, you might need it someday.
Interesting...I will be towing, but no hill's. I installed two 14 inch high RPM fan/s each having its own relay and thermostat. Hopefully it will handle the summer weather
Blown 331
12-24-2009 04:57 PM
hillbillydaddy87
03-03-2009 01:45 AM
redrush40
07-11-2006 08:38 PM
