Hollowed out cat will it still pass emissions?
Old 01-12-2010, 07:32 PM
amsk8er1983's Avatar
amsk8er1983
amsk8er1983 is offline
I have an '05 excursion and I live in colorado where we have emissions. I have a 4" turbo back exhaust with a muffler delete and I also have the egr delete system with the valve still there. If I hollow out my cat will it still pass emissions? I know I will pass the visual inspection but I am worried about the smog test?
Old 01-12-2010, 07:40 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
PETE'S_6.0PSD is offline
do you have tuner?
if you do , than have somone write you a tune for smog testing.
all they have to do is take the fuel out, and drop your rev limiter less fuel less rev and noone will know hehe, no soot no problem.
Old 01-12-2010, 07:45 PM
amsk8er1983
Yeah but I have the edge jucie could I just put it in the stock setting or level one?
Old 01-12-2010, 08:05 PM
PETE'S_6.0PSD
i doubt it. SCT yes, not edge. i dont think anyone makes custom tunes for edge.
get SCT dump edge on ebay, and you will never look back. more power better tunes, and safer too.
Old 01-12-2010, 10:37 PM
amsk8er1983
Yeah that's what I am finding out one of the main reason's I got the edge was because of the adjust on the fly and it's not that great.
Old 01-13-2010, 07:51 AM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
Agree - I was told shift on the fly was critical and never found that it was
especially now that the SCT gives better mpg, et's, and drivability that I never change it !
and doubly so once I heard of all the tranny failures because of the edge not programming the tranny computer...
but if you haven't gutted your cat, I would think long and hard before doing that....
they are EXPENSIVE to replace when you need to....
removing it won't help you much... it flows pretty well, and unless you are going for a race truck... not worth the chance of a $10,000 federal emission tampering fine
I had my cat off the 03 Ex for a bit when I did my turbo back and put it back on...
only real difference was a little different sound ...
even at the drag strip, the difference was hardly noticable....
less of an effect than a temp change or traction issue
good luck !
Old 01-13-2010, 10:12 AM
rocky1074's Avatar
rocky1074
rocky1074 is offline
If you really want to dump the cat, purchase a cat delete pipe and you can put the cat back in before your emissions test.
03-07+ Ford 6.0L Powerstroke Diesel Cat Delete Pipe
Old 01-13-2010, 11:50 AM
cartmanea's Avatar
cartmanea
cartmanea is offline
It will probably pass just fine without the cat. They just do a snap throttle test for smoke, check OBDII codes, and a visual inspection.
Old 01-13-2010, 11:53 AM
bpounds's Avatar
bpounds
bpounds is offline
If CO does a tailpipe sniff test, it may fail. Most states don't do that for diesels, but I don't know about CO. If they just do the visual, smoke, and OBD test, it should pass okay.
I agree about it being a waste of time to delete it. Other than sound, mine ran the same with and without it. With it the exhaust smell was a little less acrid, but even that was only after a long hot run.
Old 01-13-2010, 01:08 PM
hangon2me's Avatar
hangon2me
hangon2me is offline
Mine passes the emission test. Lower emissions without this crap installed.
Hollow it out, delete your EGR and do a CCV reroute.
Leave the EGR valve in the manifold plugged in, this
is for the visual "Tampering" test and keeps the ECM happy.
Here are my results as of December 2009 (sniff)
Opacity Standard (max allowed) 20.00
Opacity at 50 MPH .40
Opacity at WOT 1.00
Before the test I return my truck back to stock tunes.
I recommend ditching the "edge juice" and buying the SCT.
I ruined my last trucks transmission running the Edge.
Old 01-13-2010, 03:22 PM
zhilton's Avatar
zhilton
zhilton is offline
If you want to burn the money you could drop the $50-$60 for an a/m delete. Or you could do what I did for $20.
https://www.ford-trucks.com/forums/9...ete-sorta.html
I still have my OEM kitty sitting in the back of the shop...just in case I need it some day.
Old 01-13-2010, 05:39 PM
amsk8er1983
hey hangon2me do you live in colorado?
Old 01-13-2010, 06:17 PM
hangon2me's Avatar
hangon2me
Nope just next door, Utah....
Old 01-13-2010, 10:56 PM
ford7379trucks's Avatar
ford7379trucks
ford7379trucks is offline
Originally Posted by PETE'S_6.0PSD
do you have tuner?
another reason to get a SCT
isn't the reason to delete the cat to get your EGTs down?
Spencer Murray
05-04-2017 11:48 AM
2wdDezlX
06-09-2016 11:14 AM
NCfisherman
1999 to 2016 Super Duty
19
07-05-2014 10:49 PM
madmiggie276
13
01-31-2012 08:43 PM
Quick Reply: Hollowed out cat will it still pass emissions?
