Speaker/Radio - Issue?
Old 01-11-2010, 07:59 AM
great white's Avatar
great white
great white is offline
When the volume on the radio is low my drivers side front speaker doesn't emit sound but the other 3 speakers work fine. When I increase the sound level the front drivers side speaker kicks in and I have sound on all four. I then decease the volume and all four speakers are fine. Do I have a speaker on the fritz or something else? Any ideas?
Old 01-11-2010, 09:30 PM
nsandera's Avatar
nsandera
nsandera is offline
I've got the same problem as you do it sounds like, I have found that if I hit the door right above the speaker it starts working again.
2004 F150 SCREW 4.6
Old 04-04-2010, 10:55 AM
broncobilly66's Avatar
broncobilly66
broncobilly66 is offline
Ive got the same exact problem.. same door too.. Did u fix yours? Is it a blown speaker or what? Its driving me nuts.. Thanks
Old 04-05-2010, 01:14 AM
bcrab's Avatar
bcrab
bcrab is offline
Mine used to do that.
I pulled the the door panel and cleaned and blew out the speaker connectors. Mine were getting wet, shorting out the connection and one of the wires was lose inside the connector. Sometimes going over a bump the speaker would go on and off. I also wrapped some electrical tape around the connector to keep the water out after fixing the lose wire.
Old 04-06-2010, 02:35 PM
pearsonrb's Avatar
pearsonrb
pearsonrb is offline
I also had this problem. There were actually two causes. As was already metioned, I had water inside the contacts. I blew it out, dried it off and used some dielectric grease when I put it back together.
It was OK for a while, then it cut out again. Turns out the speaker wire was broken between the door and the truck inside the flexible rubber boot from opening and closing the door. I splice it back together with a crimp connector.
Old 04-06-2010, 04:36 PM
flamingblue10's Avatar
flamingblue10
flamingblue10 is offline
check your wires it is very easy to pull the panel off and check the speakers to make sure they are working.
Old 04-24-2010, 02:53 PM
madmann's Avatar
madmann
madmann is offline
thought I was the only one but mines a little different every time i turn left the volume goes down (possibly the drivers door speaker). It takes forever to get to work only turning right.
KhanTyranitar
Aerostar
54
05-31-2020 11:33 AM
Amicus
10-06-2016 11:11 PM
2lionel
1997-2006 Expedition & Navigator
03-06-2012 05:48 PM
Ace!
09-27-2008 02:23 PM
2004lariat
07-03-2004 11:23 PM
Quick Reply: Speaker/Radio - Issue?
