lost wrench maybe in motor plz help
Sounds crazy but yeah, I lost the 5mm allen wrench I was using while taking off the aluminum oil return for the front injector on the drivers side. I can't find it anywhere and was wondering if it is possible to fall down in the motor through the pushrod hole? Looks like it is. See there I slipped on the wrench and took the light out too so I couldn't see where it went. I took the front rocker off and pushrod out and stuck a magnet in there, searched all I can with a light of course, just can't find it anywhere. Didn't want to stick the magnet too far in and pull out the lifter or something else to keep my streak of good luck going. Maybe its fallen amongst the engine accessories on the front of the motor, but I searched and can't find it. I have my turbo off now too so I stuck a magnet in the valley from there towards the front and everywhere else I could and can't find it.
My stress level is through the roof which doesn't help an ulcer at all. Am I going to have to pull the motor apart to look in there?? I'm just going nuts thinking about it. Does it do any good to pull the intake off and look in there? Doesn't look like it to me but I could be wrong.
Someone please lead me in the right direction if I have to pull it apart.
Going to search this morning again. The only three places it could be that I can think of is amongst the ac or ps, in the dreaded valley somewhere I can't see, or in the motor. Like I said I took out the light at the time the wrench slipped and know right where it "should" be.
WISH ME LUCK
WISH ME LUCK
on
Well I dug around this morning and didn't find anything yet. I even stuck a little but powerful magnet taped on a "snake" light down there and could see everything good. I saw no signs of the allen wrench. Keep in mind its fairly big, although it was a short one its is a 5mm which is good sized. I have another one of the same size and sat it over by there and just can't see how it could have gotten down there and disappeared.
There is no way it could have gotten past the lifters is there? Is there anywhere else it could have gone inside the head that I'd be missing?
Took about 15 minutes and pulled out glow plugs this morning (I'm sure glad that went easy for me) otherwise spent time looking inside head and all around for this @#$%^&* wrench with no luck yet.
Well, after a few more hours, still nothing. Anybody know where to see some pics of the engine without the heads so I could relate what I'm looking at through small holes to a clear picture????
I just can't believe it's down in there anywhere or I would think I'd be able to see it or catch it with a magnet
Any more input on what I said in post 10??
Sorry to keep dragging this on but I'm stressed to the max and looking for any advice.
Thanks for your help so far
Won't have too much time to look today, but I will a little.
The way my luck is going, I decided to send my injectors and the stage one DIY kit in to Jim and let do the upgrade on them. My time may be tight now that I may have to pull the head. DIY sounded like it could be kinda fun tearing into them and learning more but..................
