.....Blink.......Blink...............Blink
It would be on the fuse block on the drivers side kick panel. A round shaped piece about the cicumference of a $.50 piece ( WHY DONT THESE KEYBOARDS HAVE CENT SYMBOLS).
There is one in the front and one behind that block, so to get to the one in back you have to unscrew the whole block. I don't remember which is which, so you may want to just pull the front one and replace it first and see what happens. Pretty sure these are very economical parts but have never priced them.
I always call them flasher relay. Yes there are heavy duty ones, as already stated, just ask your parts man at Napa, or Auto Zone, or whereever you go. Not so sure that WalMart will have the selection as a parts house.. If your flasher is slow chances are it is just getting wore out, and you just need a new one.. also some times slow flashing is an indication of a burned out bulb in the front or rear of the vehicle and it is not a big enough load on the flasher to make it heat up and flash as it was designed too..
will32_
24
09-28-2014 10:18 PM
