what next??
Old 01-07-2010, 09:12 PM
starmilt's Avatar
starmilt
starmilt is offline
Warozz if you like wiring you should do the headlight mod so your switch never wears out.
  #32
bigottis1986's Avatar
bigottis1986
bigottis1986 is offline
i forgot to mention I went thru all my fuses first and found 2 blown one for the electric locks and the other was under the hood dont know what it was, it was a 15 smaller one dont know what its for i dont have a book, all the 40-50 amp fuses were good, so ill have to check that wire at the fuse box i know exactly what your talking about J didnt know what it was I have to replace my voltmeter first thing in the morning then ill be out checking it.
  #33
Old 01-07-2010, 09:27 PM
WarOzz's Avatar
WarOzz
WarOzz is offline
starmilt are you referring to adding relays so the power is not being drawn off the switch?
I did that mod to my 75 F250 a couple years back and added high power halogens to it.
On my 92 that I just got I have been looking into some mods, even possible HID upgrade, just need more ideas on how to get the best light out of it without burning up all my wiring.
  #34
Old 01-07-2010, 09:33 PM
WarOzz's Avatar
WarOzz
WarOzz is offline
Originally Posted by bigottis1986
Is there a way to test relays without swapping them can i use a jumper wire to see what happens?
Yes you can test the relays in the car or pop them out and test them. I have a link somewhere that describes it in detail, let me hunt it down for you.
I just saw your last post were you mentioned the blown fuses... 2 blown ones like that are pretty good indicator that either A) a bad ground... check for loose connections or corrosion around terminals were wires are grounded B) a dead short... meaning a positive wire has hit ground someplace.. check for wires that have bad insulation usually found were wires can rub up against metal.
  #35
Old 01-07-2010, 09:53 PM
starmilt's Avatar
starmilt
starmilt is offline
Yea thats what I'm talking about I'm running h3 120 watt high beams on my pickup.
I dont know about headlights but we run the big hid off roads lights and they don't pull that much juice we either run relays or constant duty solonoeds. I have trucks using both and the solonoids last longer seems like and doesn't have to be as protected.
  #36
Old 01-07-2010, 10:31 PM
WarOzz's Avatar
WarOzz
WarOzz is offline
I think I will do the relays this weekend, the h3 120's sound pretty nice too. The HID kit and clear lenses are probably going to have to wait a while due to all the other stuff on my truck wish list lol.
I really don't do any off roading other then my 2.1 mile dirt road I live on, my main goal is to get the best highway lights I can. 45 mile round trip daily on a country highway with lots of deer = big bumper guard and very bright lights.
Hey bigottis1986 found that link, check out this site for relay testing.
How Do I Check My Car Relay and Control Circuit?
  #37
Old 01-07-2010, 11:12 PM
starmilt's Avatar
starmilt
starmilt is offline
lol all mine are highway lights you just dim them as soon as you see lights.
  #38
Old 01-07-2010, 11:21 PM
WarOzz's Avatar
WarOzz
WarOzz is offline
LOL nice! I could actually get away with that here... usually only pass a logger or two heading out when I am heading to work at 4am and never any cops at that time of the day.
  #39
Old 01-07-2010, 11:24 PM
starmilt's Avatar
starmilt
starmilt is offline
They let us run them in alaska and the yukon but bc makes us cover them up.
  #40
Old 01-07-2010, 11:42 PM
bigottis1986
well i fixed my voltmeter fuse was blown in it, just bypassed it with a wire, beings a cheap wally world special. So ill brave the cold for a little bit and check the fuse box in the engine compartment anyways, much more than that will have to wait. It wouldnt start right now anyways with -6F as high friday
  #41
Old 01-08-2010, 12:07 AM
bigottis1986
[IMG]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
i just found this diagram and the fuse i replaced was for the backup lamps, I dont know what see fuses mean does it mean the ones inside truck? Also looks like the only relay to look at/test is TECA Power relay.
  #42
Old 01-08-2010, 12:38 AM
j tate's Avatar
j tate
j tate is offline
[IMG]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]http://ww2.justanswer.com/uploads/16vvincent/2009-02-08_035758_73-engine-fuse-box.jpg
i would have to guess yes, the ones inside the truck.
  #43
Old 01-08-2010, 11:14 AM
bigottis1986
well i have power to the fuse box in engine compartment now what?? All the fuses are ok there and in the truck, the only thing i couldnt get was the relays i couldnt get em out tho i was shaking from being so cold. the only relay i need to check that would do anything is the Teca After that im at a loss.
  #44
Old 01-08-2010, 11:25 AM
bigottis1986
does anyone have a wiring schematic they can send me or anything? So i know where fuseable links are cause if relays and fuses are good thats my next step.
  #45
Old 01-08-2010, 09:45 PM
WarOzz's Avatar
WarOzz
WarOzz is offline
I will try to scan my schematics and send them to you.
Quick Reply: what next??
