what next??
#46
#47
#48
#49
#50
Have you removed the fuses and reinserted them?
I think I would be looking at the contacts under all of the fuses.
Pay close attention to I, J, K, L, N, P, R, and S.
Then I would also check the fuses inside since J, L, N, P, and S feed them.
Grounds is another good possibility, you have to have a complete path from the battery to the device and back to the battery for electrical items to work.
Since this affects so many circuits at one, I think a ground problem is even more likely unless it is a power problem between the battery and the under hood fuse panel.
#51
i will be checking the grounds sunday! I brought them in and they have a reading of 100 and 95% so the batteries at least test good on battery charger. My grandpa said they can freeze and that would ruin them, is this true? Also i checked water levels which were full and the metal inside is white on some instead of grey is this a issue?
#52
#53
so since they both had at least 95% charge it shouldnt of froze. so before i reinstall them I will clean ground connections and then the Fuzes you told me Dave. I thank everyone very much for helping me and putting up with me, electrical is not my strong point. You guys are saving me from a HUGE Repair bill from a garage, so my sincere thanks and appreciation goes out to you all. Im Hoping and praying it'll be up and running sunday afternoon only having 1 car sucks, especially going from my truck to a Neon...
#54
#57
ok ill have to look there The passanger side battery is was to trace its on the block also kinda by the harmonic balancer a little to the right towards the (passanger side) of it, just didnt know about the driver side. Also with the dome light working not bright when i pull to turn on the headlights the dome light goes out but no headlights.
#58
#60
