Oil Leak
That is the typical sign that the oil cooler o-rings are beginning to let go. If you wait too long, the inner water jacket o-rings will allow the coolant to get into the crankcase and then you will have a big nasty mess.
Cody just posted a nice writeup on changing the oil cooler o-rings and gaskets.
Oil Cooler Repair.
Oil Cooler Repair.
Here's an exploded view.
And an oil cooler O-ring fix procedure: Oil Cooler O-ring swap.pdf
And: Oil Cooler Seal Kit At Guzzle's Diesel O-rings.
ChaseTruck754
387
04-20-2017 04:22 PM
mtflat
22
01-31-2011 07:50 AM
ChaseTruck754
20
01-12-2010 06:23 PM
