Truck was broken into, quarter glass window needs replaced
Old 12-30-2009, 06:10 PM
BlackNGoldRules's Avatar
BlackNGoldRules
BlackNGoldRules is offline
I need some advice guys. Someone recently broke into my ranger destroying the quarter glass window on the passenger side rear door of my supercab. Well, I've been quoting some prices to have it replaced and the average price has been around $400 or more. I can't believe it's that expensive for that tiny little window! My deductible is $250. I was thinking the price wasn't even going to reach the deductible but I was dead wrong on that. Anyway, is there a way I can get a used window and have that put on instead? I want to find the cheapest sollution possible for this. Thanks for any advice.
Old 12-30-2009, 06:20 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
If you can find one at a wrecking yard you can even do the repair yourself.
To remove the quarter glass window: remove the interior trim to gain access to the window fasteners and unscrew them, then cut the sealant around the window with a razor knife, and it should right pop out.
Old 12-30-2009, 09:39 PM
BlackNGoldRules
Are there any tutorials or some kind of instructions on how to remove and replace the window? Maybe I will try and do it myself if it's not a complicated thing to do. Better then spending $250.
Old 12-31-2009, 12:08 AM
Rockledge's Avatar
Rockledge
Check out: Removing Ranger Quarter Glass Window
Your gonna need a T-50 "torx" socket for the seat belt.
Old 01-01-2010, 01:30 AM
BlackNGoldRules
Could you tell me what the best way is to remove the cover that goes over the bolt on the seat belt? I don't want to break it trying to get it off. Thanks.
Old 01-01-2010, 10:40 AM
Rockledge's Avatar
Rockledge
Are you talking about the belt guide cover? At the widest part of the cover pull the sides out a little and then push up. The cover should pop off the bolt head, and swing open (there is a hinge at the end).
Old 01-02-2010, 07:37 AM
BlackNGoldRules
Thanks for all the info. Another question to bug you with, does it matter what temperature I do this in? I'm asking that because of the new sealant I'll have to apply. If I do this on my own it's going to have to be outside in the cold. Right now, temps are going to be below freezing here for at least the next several days. Thanks.
Old 01-02-2010, 08:47 AM
Rockledge's Avatar
Rockledge
Did you pick up the sealant yet? Most products like that have on the label a temperature range for proper installation.
Old 01-02-2010, 10:02 AM
michigan66's Avatar
michigan66
michigan66 is offline
Is just the glass broken or is the framing of the window also damaged? If it is just the glass, can you undo the fasteners that go through the glass and get replacement glass at a salvage yard. If that is the case, the replacement job will be much simpler and can be done in any temperature.
Old 01-02-2010, 11:03 PM
BlackNGoldRules
I actually haven't even started yet but from what I can see it's just the glass of the window that is broken. So, I can just take the window pane out and put the used one in without having to cut the old sealant out and reapply the new stuff? The diagrams and instructions help a lot but I guess I'll have to get started on this and see everything for myself since I've never done this before.
Old 01-04-2010, 03:23 AM
BlackNGoldRules
Another question, once I get the bottom part of the seat belt off, is it just a matter of prying the panel off with a crowbar or long screwdriver? Is there a certain way to do this so I don't crack or break anything on the panel? Thanks.
Old 01-05-2010, 02:19 AM
BlackNGoldRules
OK, I got the door panel off finally. Looking at the window, where are the fasteners that you are talking about and how can I get to them to just remove the glass itself? All I can see is the 4 screws coming through with the nuts that screw off of them. I guess that would remove the whole thing. How can I get to the fasteners so I can leave the frame part of it on? Is it possible with that kind of window?
Old 01-11-2010, 02:19 AM
BlackNGoldRules
Sorry to start an old thread back up, but I found a used quarter glass window and managed to get the old one off of my truck. I bought 3M Windo-Weld Super Fast Urethane to apply to the window that I'm about to put on. Is this good enough to use? In that link that shows how to install and uninstall the window, it says to use a urethane sealant. Is what I described considered a urethane sealant? It just says super fast urethane so I just want to make sure I'm using the right stuff for this. Thanks.
Old 01-11-2010, 05:20 AM
Fordsflylow's Avatar
Fordsflylow
Fordsflylow is offline
Reads like you have the right stuff.
Old 01-12-2010, 09:54 PM
reddog99's Avatar
reddog99
reddog99 is offline
The pdf spec sheet for the Super Fast Urethane says, "Please note that bonding is not recommended below 40°F.".
Quick Reply: Truck was broken into, quarter glass window needs replaced
