1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Bad wheel bearing/hub assembly?
Old 12-29-2009, 06:50 PM
vahunter2469's Avatar
vahunter2469
vahunter2469 is offline
I have a 2001 F250 SD V8 5.4 4x4 with on-the-fly hubs and ABS. Just bought the truck and dont know too much on these Fords (I can tell you all about Toyotas pickup and Tacomas though). On the pass side my front hub assembly or wheel bearing assembly i believe is worn. If i grab the axle u-joint i can wiggle it all around particularly around the wheel. Would I replace the hub assembly or just the bearing? Im tight on cash so im hoping that i can get out cheap.
Are the AutoZone Valucraft ($114) crap? AutoZone.com | | Wheel Bearing/Hub Assembly-Front | VALUCRAFT HUB BEARING or would i have to buy a Timken assembly($325+)???
Old 12-29-2009, 07:50 PM
mrford60's Avatar
mrford60
mrford60 is offline
there is a small roller bearing that the axle rides on inside the hub, it can be replaced seperatly at alot cheaper price, if the wheel wobles then its the expensive hub bearing
Old 12-30-2009, 11:07 AM
david0505's Avatar
david0505
david0505 is offline
If You decide on Timken,You might want to run the Timken number thru:carpartscloseouts.com....Dave
Old 12-30-2009, 04:28 PM
Rugby3's Avatar
Rugby3
Rugby3 is offline
You can get the hub from Napa with Timken bearings in it for $234. I don't have the p/n on hand but I am sure that most Napa's have them as stock items. Mine did and it's a rinky dink small town.
1973Ford2004
32
04-22-2024 02:55 PM
Racerguy
764
08-15-2023 02:03 PM
Raise
22
03-26-2017 12:27 AM
Codelizard
01-17-2017 12:06 PM
sowaxeman
16
01-29-2016 08:37 AM
Quick Reply: Bad wheel bearing/hub assembly?
