loud noise amplified through airbox?
help please? driving the truck today and it started making a thumping sound that seems to be coming through the air box? went away a couple of times so i drove it home but noise got louder. got the truck home and shut it down and let it sit for two hours, went back and it started hard and the noise was still there. any thoughts? thank you.
If you can hear it while standing outside looking at it, then it's not the intake hose colapsing. Unless it has a separated piece inside it. Can you pull the intake hose and start it with open turbo and see if you hear it? Also, is the air filter box closed tightly, if so is the filter snug in there? There should be nothing that makes this sound you are describing. Only other thing that comes to mind is maybe a burnt intake valve that's pushing air back through the intake stroke causing the turbo compressor to surge. I'm at a loss here.
Open the air box and start the truck, take a look. Or don't start it, just open the air box on look around to see whats broke or has marks that should not have marks.
Check the hose, give it a squeeze, see if it collapses real easy or not. Tell us what you see, or post a picture if you aren't sure.
And someone that knows about electrical stuff look at the volt meter delay thread, I posted a video...But don't respond here cause then this gets
So I just got back in a whopping 9 degrees out there. found the problem, a broken push rod. unfortunately, in the process of getting there i broke the radiator as well. so now that im there should i replace all of the rods? Is there anything else i should do while im in there? thanks
Inquiring minds want to know?
