2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
How to mount a cargo net in 07 expedition?
Old 12-27-2009, 02:22 AM
2001gocougs's Avatar
2001gocougs
2001gocougs is offline
I have purchased a cargo net originally intended for an excursion to mount in my wife's expedition. We have a steep driveway that is always causing cargo to roll out. Is it safe to remove the trim pieces at the rear to mount a D ring attachment?
If I can't mount it to the walls I was planning on building a fold up frame from the jack storage area.
Old 01-03-2010, 03:37 AM
threefiftyone's Avatar
threefiftyone
threefiftyone is offline
I have the same dilemma. I was thinking of just screwing rings into the extremely cheap plastic in the rear over the wheels. Another thought i had was to mount one side of a net under the jack storage cover, the the other side to the door somehow. When you open the door, the net would stretch between the door and the floor ultimately trapping anything from rolling out. Crude, but a simple preventative measure - reach in from the sides to retrieve cargo. Just a thought, good luck
Old 01-03-2010, 08:42 AM
eddiemoney's Avatar
eddiemoney
eddiemoney is offline
When I installed a net in a 2005 Subaru Forester it had funky rubber screw things. Basically you drill a half inch hole, stick the screw rubber thing through the hole, when you tighten the screw the rubber that is now behind the panel mushrooms out to create a pressure fit. It seems to work/hold very well. I imagine you could use something similar, just have to find a net wide enough.
Erzebet
2015 + Expedition & Navigator
04-11-2018 03:11 PM
pdc76
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
02-02-2016 02:52 PM
sessland
01-25-2015 09:10 AM
OkieLEO
04-26-2014 12:22 AM
skytower31
01-18-2013 02:44 PM
Quick Reply: How to mount a cargo net in 07 expedition?
